Electronic Fuel Pump Question http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=11609 |
Author: | tsutxn09 [ Thu Aug 12, 2010 10:26 pm ] |
Post subject: | Electronic Fuel Pump Question |
The more i read on this forum the more i think i need to install a e fuel pump on my 25hp kohler gd longtail. So ive got some questions. Do i bypass the mechanical fuel pump? Do i take the primer bulb out? Do i just wire it to the ignition switch? Thanks for the help guys i need to get this sucker running ive got t minus 29 days and counting for the small duck season. |
Author: | SP [ Thu Aug 12, 2010 10:49 pm ] |
Post subject: | Re: Electronic Fuel Pump Question |
I installed one last year, and it made a big difference for me. The engine runs much better, and starts right up. I wired the Fuel Pump directly into my starter. Turn the key, let the Fuel Pump run for a couple of seconds and then start it up. You need to check to see if your fuel pump is a push or a pull pump. Mine is push which should be installed as close as possible to the fuel tank. I have the fuel pump installed on the bow, and then the line runs into a primer bulb, into a water seperater, into a quick connect, and into the engine. I originally took the bulb and quick connect off and ran the motor, and then put them back on, and ran the motor. There was no noticeable difference for me, so I put them both back on. The bulb is a back up in case the Fuel pump goes out, and I like having quick connect to burn the fuel out of the motor(much easier, and I do this about every time I run the engine). The only thing you could add is cut off switch to the fuel pump so you can turn it off. I hope this helps. |
Author: | deadbird8 [ Fri Aug 13, 2010 6:26 pm ] |
Author: | tsutxn09 [ Fri Aug 13, 2010 7:20 pm ] |
Hey guys thanks for the help i just got a mr gasket e pump bout to go install will post some results after i get it on |
Author: | Chico80x [ Mon Sep 13, 2010 3:39 pm ] |
How did the install go and did it improve the way your motor runs? |
Author: | tsutxn09 [ Mon Sep 13, 2010 4:05 pm ] |
still trying to work bugs out of the motor so i took the thing off ill let ya know when i get everything running |
