It is currently Mon Jun 30, 2025 2:50 am
Reply to topic  [ 7 posts ]
 Can someone shoot me an iPhone vid to install timing advance
Post Can someone shoot me an iPhone vid to install timing advance
Key or point me to a video link. Need a little help. GTR23 vanguard 23
Mon Sep 06, 2010 6:21 pm
Post Re: Can someone shoot me an iPhone vid to install timing adv
...little help, little help here for a brother.
Question: does removing the fly wheel require special pulley or something. And, what torque to apply when reinstalling?
Tue Sep 07, 2010 7:50 pm
to remove the flywheel you need to stop the crankshaft from movin. i think they tourque it to 100 lbs but dont hold me to that.
Tue Sep 07, 2010 8:06 pm
Use a flywheel holder, unbolt nut, and tap flywheel off using a rubber mallet.
Just a wild guess an impact wrench will work with the quick blast to remove the nut. I dont know the Torque when re installing. Maybe someone can help you more in that area.
Heres a flywheel holder.
Bayou Surface Drive
337-351-0362
Tarkington, TX 77327
Wed Sep 08, 2010 6:38 am
I usually just tighten the shiznic out of it with the electric impact. When install the key make sure it looks like a S and not a Z.
Don't mistake my kindness for weakness, my ability to look over things as ignorance - but make no mistake, when I've had enough, I'm Coming After you. Watch Your Back....lol
Wed Sep 08, 2010 9:05 am
Wed Sep 08, 2010 3:11 pm
When looking at the flywheel, the key should look like an S. As in the flywheey is clocked more clockwise.. Hence advancing the timing........
Not sure on the 23 carbs if any adjusting is needed.
Bayou Surface Drive
337-351-0362
Wed Sep 08, 2010 3:18 pm
Users browsing this forum: No registered users and 122 guests
