recoil start for briggs 35? http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=11649 |
Author: | zackistre [ Sun Aug 15, 2010 1:22 am ] |
Post subject: | recoil start for briggs 35? |
Hey guys I was just wondering if they even make pull start for a 35 or if it will work. I really would like to have this as backup and was seeing if any one knew where to get it or any other suggestions thanks zack. |
Author: | kibb [ Sun Aug 15, 2010 6:15 am ] |
Post subject: | Re: recoil start for briggs 35? |
I guarantee if there is a recoil for it and you can crank I will not f**k with you. You better be a gorilla cause I don't think it is humanly possible. |
Author: | brlcla [ Sun Aug 15, 2010 7:31 am ] |
I have never seen one but that doesnt mean they dont exist.... the thing about the 35 is that you have to have a battery hooked up to make it run... that plays a lot in the reason that one may not exist. but it would be beneficial if you ever have starter issues. |
Author: | bjg [ Sun Aug 15, 2010 10:39 am ] |
It runs without a battery, its just that the clutch will not work untill the charging system starts putting out at 2000rpms. |
Author: | benny365 [ Sun Aug 15, 2010 12:56 pm ] |
we don't all have clutches... ![]() ![]() ![]() ![]() |
Author: | brlcla [ Sun Aug 15, 2010 1:19 pm ] |
well... from what i have been told is that the 23HP is the largest motor that will run w/o a battery... once again that is what I have been told so may not be the truth |
Author: | shallow water master [ Sun Aug 15, 2010 1:32 pm ] |
X2 they will run with out the batt. Hooked up |
Author: | deadbird8 [ Mon Aug 16, 2010 5:43 am ] |
Author: | brlcla [ Mon Aug 16, 2010 4:18 pm ] |
thanks db8 i knew there was somewhere I read you needed a 12v supply to run the motor... |
Author: | cb5331 [ Mon Aug 16, 2010 4:33 pm ] |
I know my kohler won't run with out the battery, and neither would my dads 32 briggs. Probably something to do with the backfire solenoid like yall are saying. |
Author: | HUNT4DEER [ Wed Aug 18, 2010 2:52 pm ] |
recoil = dis located arm. you would have to be a bad mofo to get it started. prob better of sucking the exhust pipe. |
Author: | latravcha [ Wed Aug 18, 2010 3:07 pm ] |
I have heard that there are a few people on here do have enough suction to do it |
Author: | Joe M [ Wed Aug 18, 2010 5:04 pm ] |
Author: | Chico80x [ Tue Sep 07, 2010 9:34 pm ] |
I don't think it's humanly possible to get this engine pull started either. I had a battery go out one time on my 660 one cylinder atv with a decompression cam and all, and I had one hell of a time getting it started. It was definitely no lawn mower so I can even imagine how hard you would have to pull to get a V Twin engine started. |
Author: | SMELVIN [ Tue Sep 07, 2010 9:55 pm ] |
i am sure if you can catch the motor just right off the compression stroke you could pull start it but its still going to take a big ole boy |
Author: | brlcla [ Wed Sep 08, 2010 4:34 pm ] |
I would go the electric impact on the flywheel hahaha........................... better yet how about just carry a jump box and not worry about a dead battery... |
