It is currently Sat Jun 28, 2025 11:32 am
[ 6 posts ] |
rob_rides_03
Joined: Tue Oct 13, 2009 3:31 pm Posts: 202 Location: NJ
 throttle issues
having issues with the throttle on my 25 kohler...motor starts fine, and runs well...however...when you give it gas the motor coughs, bogs a little bit, and then gets through it and runs fine after that...also the throttle can get stuck and i have to rev it to free it up back to an idle...also seems like the cable needs to be adjusted as it gets to WOT before the cable is fully extended?
does the carb just need to be pulled off and cleaned? im not sure what would make the throttle stick like that though...no kinks in the cable
thanks
Sat Aug 21, 2010 1:30 pm |
earl33
Joined: Wed Sep 16, 2009 3:47 pm Posts: 2261 Location: West Tennessee
 Re: throttle issues
Give it a good cleaning and see what happens...
_________________ If the Steel aint Flying the Birds aint Dying.... Uncle J 1948 holding a LT Uncle J 1848 w/?
Sat Aug 21, 2010 1:52 pm |
Team Camo
 Re: throttle issues
My 27 did the exact same thing straight outta the crate. Never did get it figured out, just learned how to work the throttle to make it roll thru it. Those cable get moisture in em and tend to stick or hang up. Best to just keep it lubed up & always expect it to hang up at WOT when ya need to back down NOW.
Sat Aug 21, 2010 2:55 pm |
rob_rides_03
 Re: throttle issues
alright cleaned it out...now theres a new problem....
motor seems to idle rough but the throttle response is much better with little or no bog....but when you rev it out to WOT it gets up there for about a second and then coughs out and dies....
i let it warm up to see if it needed to clear out but the issue still remains
Sat Aug 21, 2010 3:03 pm |
rb777
Joined: Thu Jan 21, 2010 12:18 pm Posts: 41 Location: North
 Re: throttle issues
I have a similar issue and was told the high speed jet needs attention/cleaning.
_________________ " I am the way, the truth and the life, no one comes to the Father but through Me"...Jesus Christ
Sat Aug 21, 2010 10:22 pm |
craig
 Re: throttle issues
Sat Aug 21, 2010 10:33 pm |
[ 6 posts ] |
Users browsing this forum: No registered users and 118 guests |
