It is currently Mon Jun 30, 2025 8:15 am
Reply to topic  [ 20 posts ]
 Twin Mikuni Vs Single Mikuni
Post Twin Mikuni Vs Single Mikuni
I tried searching the Forum. Can anyone post what their gain in MPH was after going from the Single Mikuni to the Twin? I am not concerned with your actual MPH after the Twin. I am considering going to a Twin and wondering if I will get 2 to 3 MPH gain or more?
Tue Jul 20, 2010 4:09 pm
Post Re: Twin Mikuni Vs Single Mikuni
Let me ask you one question..
Why do you want to go 3mph faster?
Tue Jul 20, 2010 7:19 pm
You'd lose bottom end with the duals.
Tue Jul 20, 2010 7:30 pm
what mods do you have and is it a cdi motor?
Tue Jul 20, 2010 8:26 pm
what is the difference with the cdi?
BUSTIN' SOME BEAKS!!!
Tue Jul 20, 2010 9:16 pm
Tue Jul 20, 2010 9:19 pm
sweet thats what i wanna hear lol. just ordered the black death 5500cdi
Tue Jul 20, 2010 9:26 pm
that 5500 has some big power you will be very happy and congrats on the purchase
Tue Jul 20, 2010 9:30 pm
thanks bud. positive input sure makes a cheap a$$ like me feel better about spending all that money. lol
Tue Jul 20, 2010 9:34 pm
Wed Jul 21, 2010 4:14 am
Wed Jul 21, 2010 2:46 pm
There is no guaranteed MPH gain when switching to the twin setup. Every boat and every motor will take the change a lil different. Somewhere in the 3-5 mph range sounds about right to me with the right setup, but I'm no expert. And the wrong setup may only gain 1-3 mph. You just never know. Also as DB8 said, you will more than likely lose some bottom end and gain a small amount on the top.
Wed Jul 21, 2010 4:33 pm
Is there a noticeable difference in power between the Black Death 5500 and 4500 to justify going to the dual carb set up on the cdi motor?
"We Are Products Of Our Decisions"
Thu Sep 09, 2010 9:58 pm
2011 18x54 Excel-black death 5500 MB
Fri Sep 10, 2010 12:42 am
and as far as speeds my rig wont be finished getting built untill the end of this month but most people with similar rigs are telling me they are gettin low 30's
Fri Sep 10, 2010 12:46 am
Is there any advantage at all to having the twin carbs over the single? If there isn't, why is it that all the high end mud buddy engines have the twin set up? Just so they can charge you more?
Mon Sep 13, 2010 8:32 pm
Tue Sep 14, 2010 1:23 am
What? You can't idle with a single carb? That doesn't make any sense at all.
From what I've read, depending on the boat, you may gain a mph or two on the top end, but bottom/mid range is not as strong. Single carb would be a lot easier to tune for the do it yourself type also.
Tue Sep 14, 2010 5:25 am
Tue Sep 14, 2010 5:37 am
I would think that with the twin carbs you should have better throttle response being that there is a direct path for the air/fuel mixture to enter the cylinder. They might even produce a little more power since the air entering the engine should theoretically be cooler than air that needs to pass through an intake manifold located between two hot cylinders before entering an engine.
One thing that helped me choose the Blackdeath 5500 that I have on order over the 4500 is the way the carbs are positioned. With the stock exhaust, the single carb is taking in air that is being heated before entering the engine and then heated again in the intake manifold. This might cause a slight increase in operating temperature and possibly some decreased power over the twin carb set up but, this is just my opinion.
I know that while running at a higher rate of speed, the air blowing over a single mikuni set up should make any heat coming off the exhaust meaningless and installing duals will completely eliminate the heat source altogether. I am almost certain that there should be a difference in the temperatures of the the intakes on both engines but, if it's enough to make a difference in performance, I don't know.
Tue Sep 14, 2010 9:38 am
Users browsing this forum: No registered users and 117 guests
