gtr 35 fuel/carb issue http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=12436 |
Author: | gator-tailman [ Fri Sep 17, 2010 10:46 am ] |
Post subject: | gtr 35 fuel/carb issue |
Ok,when i pump the bulb, i am getting fuel out of the line that comes out of the fuel pump, but when i connect it to the carb, i get nothing comming out of the carb unless i pump the bulb REALLY hard....any suggestions on the fix for this? motor will start when fuel is dumped into carb also my choke cable broke, any cheap fixes? |
Author: | craig [ Fri Sep 17, 2010 10:50 am ] |
Post subject: | Re: gtr 35 fuel/carb issue |
DO NOT PUMP THE BULB REALLY HARD.....YOU WILL RUPTURE THE DIAPHRAM IN THE FUEL PUMP!!!!! Only pump your bulb until you see fuel move into the fuel filter!! |
Author: | gator-tailman [ Fri Sep 17, 2010 10:52 am ] |
ok so what is my problem and how do i fix it? |
Author: | craig [ Fri Sep 17, 2010 11:19 am ] |
Does the motor run? |
Author: | gator-tailman [ Fri Sep 17, 2010 11:44 am ] |
only if i put gas down the carb |
Author: | craig [ Fri Sep 17, 2010 11:50 am ] |
Look on the bottom backside of your carb and see if your carb. is equipped with an electronic fuel shutoff solenoid. |
Author: | deadbird8 [ Sun Sep 19, 2010 4:35 am ] |
If you have the anti-backfire solenoid on the carb bowl, you should hear a 'click' when you turn the key on. You can disconnect your fuel tank and run a line with filter and primer bulb from a fuel can at the transom and see if it runs while you use the primer and manually pump. If so, your problem is on the supply side somewhere. |
