It is currently Sun Jun 29, 2025 3:53 pm
Reply to topic  [ 4 posts ]
 MB Trim problem
Post MB Trim problem
My trim on my 35hp MB is working on and off. What do you think it could be? Should I replace the swtich or the entire trim unit. This is the older model trim.
Wed Sep 22, 2010 9:49 am
Post Re: MB Trim problem
I would ck the connections before I did anything else..
they can work loose from the vibrations and bouncing....
Wed Sep 22, 2010 10:22 am
Has anyone converted the old thompson to the lectrotab one without buying the entire base. I imagine I could get something welded up to make it work. Thanks for any input.
Wed Sep 22, 2010 1:40 pm
Have you done all the troubleshooting & know for sure that the trim unit is out for sure? I'm with Caddo, most likely is a bad connection. Could be as simple as a connector that is loose, a broken wire, or even a bad relay. Before ya go drop $150 on a replacement unit, open the football & check the connectors on the switch. If that's all good, check to make sure ya have power to the switch (using a test light or volt meter). Next, check the relay & make sure it's also got power to it. If all that's good, make a jump wire to connect both posts on the relay & try the trim again. Good luck, hope it's a simple & cheap fix. ;)
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Wed Sep 22, 2010 8:48 pm
Users browsing this forum: No registered users and 139 guests
