It is currently Wed Jul 02, 2025 7:05 am
Reply to topic  [ 26 posts ]
 Black Death Intake
Post Black Death Intake
Well, I finally decided to try out the new Black Death intake. Keith form SETX Performance got me the intake, the boot, and the brush guard. Installation was easy. I'm hoping to get it in the water this weekend to get some numbers. Once I run it with this intake, I'll decide weather to keep this one, or put my EVT back on.
Anyone else switched from the EVT to the Black Death? If so, were there any gains or loss in performance? The main reason I wanted to try it was because I like the lower more compact look of the Black Death. If it runs the same or any better, I'll be selling the EVT intake.
Review to come this weekend. Here are a few pics of the finished install. I painted the brush guard with black bedliner and used it as a place to mount the Tach.
Tue Sep 28, 2010 8:38 pm
Post Re: Black Death Intake
Tue Sep 28, 2010 8:39 pm
Looks good. Like the bedliner idea- thats a good tip.
I would recommend you re-route the throttle cable if you can. If you run through some brush it can hang up and you may be accellerating without trying to. Thats also why I keep my tach down on the motor face too.
I have run the throttle two ways:
Or around the back and around- depends on your throttle cable length.
Thu Sep 30, 2010 7:15 pm
Db8....... I find the second way you show to cause the cable not to go all the way back to idle when coming off the throttle. It likes to hang up around 1500 rpms. I have to give the throttle a little flip to make it jump back down to 800.
If I can't find a cure for this I'm going back to the first way shown.
Fri Oct 01, 2010 6:06 am
I had the same throttle problams as you did bbb. And I'm not too worried about any brush catching the throttle cable the way it is because I always have the poling platform on my boat. It kinda protects the motor.
Fri Oct 01, 2010 10:58 am
So was the what was the out come?
Thu Feb 03, 2011 8:54 pm
I think he has a short term memory. He forgot to type his report.
Thu Feb 03, 2011 8:55 pm
wut did that setup run ya ive thought about swapin my old bps for the black death
16x56 epidemic slick bottom with mini 4000
Thu Feb 03, 2011 8:59 pm
Its $110
http://www.setxperformance.com/Convert- ... 123321.htm
Thu Feb 03, 2011 9:08 pm
Chop suey....what is the difference between da 2? Is the newer one better in any way over the old one?
Thu Feb 03, 2011 9:58 pm
Thu Feb 03, 2011 10:04 pm
They said they tuned it, the new intake has two distinct intake ports split in front of the carb inside the intake vs. at the intake on the older style. As stated above, its also a little lower profile.
Fri Feb 04, 2011 6:32 am
so u gettin better air fuel mixture is the thing
Fri Feb 04, 2011 7:28 am
Less restrictive flow.
Fri Feb 04, 2011 10:12 am
All i can say is i have it on mine and woulnd't have it any other way!
Fri Feb 04, 2011 10:15 am
Well i guess this new 1 he got must be awsome that he never made it back on hear to let us know!!!! I think he's still out there ridin the pig snot out of it :lol:
Tue Feb 08, 2011 7:25 pm
I got one ordered today for my new motor!!
17x48 extreme stage 2 GTR
Tue Feb 08, 2011 8:31 pm
I knew you would n't be able to leave it alone! lol
Tue Feb 08, 2011 8:46 pm
Tue Feb 08, 2011 8:48 pm
Sorry fellas, I forgot all about the review. The intake is awesome. I really noticed the difference on my low end. With the EVT, I had to feather the throttle on takeoff. I did see a gain of about 100 RPMS. I really like the fact that the intake sets the carb much lower than the high rise EVT. If you are thinking about an intake, the Black Death won't dissapoint.
Tue Feb 08, 2011 8:49 pm
Tue Feb 08, 2011 9:50 pm
Tue Feb 08, 2011 9:54 pm
Tue Feb 08, 2011 9:56 pm
I will take 30 mph and 1000 hrs!!!
Tue Feb 08, 2011 10:03 pm
1750GATOR TRAX &MB4000&MPE
Wed Feb 09, 2011 5:21 am
X3
Wed Feb 09, 2011 5:24 pm
Users browsing this forum: No registered users and 94 guests
