16 hp B&S Vanguard on GO DEVIL
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=13031
Author:  480volt [ Tue Oct 12, 2010 7:52 pm ]
Post subject:  16 hp B&S Vanguard on GO DEVIL
Could use some help. When idling or full speed the fuel filter empties and the engine sputters and then dies. Replaced priming bulb, fuel filter, 1/4 inch fuel line, fuel pump, and tank fittings. That didn't fix the problem. Took fitting off of hose and stuck hose in a gas can of fresh fuel to eliminate possible fitting or tank issue. Nothing seems to fix the problem. It doesn't seem to even be pumping fuel. HEEEELLLP!!!
Thanks in advance.
Author:  autogateman [ Tue Oct 12, 2010 7:55 pm ]
Post subject:  Re: 16 hp B&S Vanguard on GO DEVIL
might sound elementary, but it really sounds like air leaking in from a fiiting
Author:  480volt [ Tue Oct 12, 2010 8:14 pm ]
Checked and rechecked all clamps. Tried with a fuel filter and a piece of hose. Wondering if maybe an issue with carb. Added the priming bulb back and pumped it up. Can't find any possible air leaks. It won't pump any fuel at all. Could the port on the valve cover where the short hose to fuel pump connect be a possibility?
Author:  mississippiduckboy [ Tue Oct 12, 2010 8:15 pm ]
that or is the hose to long i had a problem with mine not wanting to draw up the fuel
Author:  autogateman [ Tue Oct 12, 2010 8:17 pm ]
it could def be the hose, disconnect hose from carb, pull your kill swich lanyard, and try to start it, fuel should pump out
Author:  480volt [ Tue Oct 12, 2010 8:38 pm ]
I only have 6 feet total fuel hose. I will try disconnecting line from carb tomorrow. Thanks I appreciate the help.
Author:  godevil16 [ Wed Oct 13, 2010 7:42 pm ]
fuel pump mine did the same thing
Author:  480volt [ Thu Oct 14, 2010 7:01 pm ]
New fuel line, new priming bulb, new fuel pump, new fuel tank, fresh fuel, new fitting where hose attaches to tank, and fitting on tank. Retightened hose clamps. Took hose loose from carb, pulled kill switch, turned key, and watched it pump fuel. Think maybe an issue with the carb. Fuel filter still loses prime. Can watch the fuel drain out.
