It is currently Mon Jun 30, 2025 1:06 am
Reply to topic  [ 9 posts ]
 level start safety for briggs?
Post level start safety for briggs?
does anyone know how to disable the level start on a vanguard 23?
thanks
23 MB mini w/ IM heads, BPS rockers/rods and gutted exhaust on a rivited 1648 crestliner.
Sat Oct 09, 2010 12:42 pm
Post Re: level start safety for briggs?
the two wires coming out of the sensor-just unplug them and the wire that was going to the sensor, plug it to the starter wire that the other one was hooked to./
Sat Oct 09, 2010 4:46 pm
thanks for the reply.
i'm not actually sure where the sensor is on my motor.
Sat Oct 09, 2010 11:03 pm
my motor is a kohler so not sure if its the same, but its a small cylinder, maybe 3/4 inch in diameter bolted on the side of your motor with two wires coming out of it. or you could trace the wires coming off of your starter, the small one that doesnt go back under the engine cowl should lead back to the sensor
Sat Oct 09, 2010 11:22 pm
It should just be a mercury switch. Just bypass it.
1542 war eagle 23 gator
Sun Oct 10, 2010 1:04 am
mercury switch is there for when you start the motor and your throttle is frozen wide open----= start the motor out of the water
Sun Oct 10, 2010 7:22 pm
thanks for the help!
Sun Oct 10, 2010 9:10 pm
not sure if you solved the problem yet but a simple fix is to lossen the screw that attaches the mercury switch to the motor, rotate the switch until the bottom face upwards, then retighten the screw. That way there is no cutting wires and can be rotated back when you find out that it aint such a great idea.
17*38 Klibert 23GDLT
Wed Oct 27, 2010 3:14 pm
Yea I have agree that this is a bad idea. If you did it or are going to. keep a camera close by so every one can enjoy, or do you have one of those new longtails with neutral and reverse :lol:
Wed Oct 27, 2010 6:38 pm
Users browsing this forum: No registered users and 82 guests
