Go devil Vanguard Alternator http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=14027 |
Author: | Bigwaterducker [ Thu Nov 25, 2010 5:47 pm ] |
Post subject: | Go devil Vanguard Alternator |
I have an older Go Devil 20 hp longtail with a Vanguard Motor. I just found out these motors have alternatosr. Was it designed to recharge the battery or just run certain items like lights? I am trying to find a way to keep my battery charged. Thanks |
Author: | cb5331 [ Fri Nov 26, 2010 9:51 am ] |
Post subject: | Re: Go devil Vanguard Alternator |
It's not really an alternator, but it does have a small charging system. Wouldn't swear to it, but I think on those small engine's it is < 10 amps. Maybe slightly more. It is for charging the battery. As long as you aren't pulling a load larger than what the charging system is making, it should keep the battery pretty well charged. 2 55 watt lights draw close to 10 amps, so if you are running larger lights or running that size lights for a long period of time, and not running the motor much with the lights off, you'll want to put a charger on it to keep it fully charged. Also, it's only gonna charge with the rpm's up around 2000+, so letting the motor idle isn't gonna help to charge the battery. |
