It is currently Mon Jun 30, 2025 7:01 pm
Reply to topic  [ 10 posts ]
 need help asap
Post need help asap
Hello all in route to blind and motor was driving fine then after 20 min dropped to 1200 rpms in water and will not handle load. Out of water is fine but in water it gets bogged down at full throttle I would like to fix before I head out today any help is appreciated
16x44 gd with 25 hp gdlt
Sat Nov 27, 2010 4:51 am
Post Re: need help asap
check your fuel filter and fuel...
mine did this the other day and it ended up being the valves not set right
I gave up mud motors
Sat Nov 27, 2010 5:13 am
So the vavles would be a non field fix I would think. Fuel is brand new but it is 25 today plus wind chill on car ride and boat ride, it was the weirdest thing we were going about15 then all of a sudden rpms dropped and we were lucky to go 6 under a load but if u pull it out of water it runs like no other, thank you for the help any other suggestions for stuff I could check out here would be awesome otherwise its a long ride in today!
Sat Nov 27, 2010 5:30 am
i aint no expert but it makes me think you only runnin on one cylinder?
make sure the plug caps are on good,that would be an easy,lucky fix.
if not, undo one wire,try to crank it,if it cranks stop it then undo the other side.
if it still cranks then you got fire on both sides and i'm full of shiat.
if no crank then the side with the wire on is not firing......if this is the case a swap of the sparkplugs could narrow it down to plugs.but wont do you any good unless you got new plugs to replace the bad one......or try cleaning the bad one??????????hope this helps.
Sat Nov 27, 2010 6:06 am
One day we were out in the fridgid temps, barely made it back. It ended up being the air filter was soaked,causing it to choke it out. Swore it wasn't getting fuel. Pull filter, and see.
Gator Trax 1854 ran over by drunk driver!! ( boat less)
Sat Nov 27, 2010 7:19 am
Could be any number of things....fuel tank not being vented, bad spark plug, bad spark plug wire, wet spark plug/wire, bad coil and/or coil wires, valve setting, cam could have a rounded lobe etc.
It's a process of elimination.....check your fuel tank first....if it is vented correctly, pull your spark plugs out and be sure you have good spark.....report back with results and for further consultation.
Sat Nov 27, 2010 8:49 am
Since it was cold on that day you might have experienced carb icing, which is a combination of cold temps and very humid air passing through the carb. Does the thing run ok now?
Mon Nov 29, 2010 8:34 am
If you find out that it's only running on one cylinder, it could be the diodes in your wiring harness.
Mon Nov 29, 2010 9:53 pm
Ok, so its not the spark plug, I tested the plug wire and no spark. Took coil and smart spark box off today. I have read the 18HP coil will work better than this one beings it doesn't have the smart spark box.
Sun Dec 05, 2010 3:40 pm
Did you test the smart box to see if there is something wrong from it?
Sun Dec 05, 2010 3:50 pm
Users browsing this forum: No registered users and 151 guests
