b_coonass
Joined: Thu Mar 26, 2009 2:08 pm Posts: 1229 Location: morgan city, louisiana
 Decked & polished heads
What is the advantage of decked and polished heads?
_________________ 36hp Pro-Drive with EVT exhaust pushin a 17x42 custom skiff
Tue Dec 07, 2010 7:53 pm |
autogateman
Joined: Thu Sep 16, 2010 10:32 pm Posts: 4036 Location: Gonzales La
 Re: Decked & polished heads
decking the heads shaves material off the gasket surface, therefore increasing compression. polishing is where they smooth the surfaces where the air enters the head from the intake and gives better air/fuel delivery.
Tue Dec 07, 2010 9:25 pm |
mcnemar1982
Joined: Mon Jan 19, 2009 4:03 pm Posts: 2216 Location: Walker, Louisiana
What he said.
_________________ Ideas not coupled with action never become bigger than the brain cells they occupied.
Owner DEEP SOUTH CUSTOM BOATS (225) 252-2700 Good boats ain't cheap, Cheap boats ain't good!
Wed Dec 08, 2010 12:05 am |
latravcha
Looking to deck my heads what would yall consider a safe amount to shave with max advantage .50, .60?
_________________ Aucoin 20X48 36pd Lock your wife and your dog in the garage for an hour. Then open it and see who's happy to see you.
Wed Dec 08, 2010 9:22 am |
OwenDickeson
Wed Dec 08, 2010 12:08 pm |
chad454
my heads are in the machine shop right now and im getting them decked .60
_________________ 17x52 x-treme with 35-GTR Stage 2.25
Wed Dec 08, 2010 12:30 pm |
Jamie B.
Chad are you running stock pistons are shaved pistons?
Wed Dec 08, 2010 12:34 pm |
quackconsumer
First off nobody is deckin heads .60 .50 .30 or .20 BPS ~ .03 Hoyt~ .02 I would not recomend anything past .06 Most EVT heads were done at .05
Wed Dec 08, 2010 12:40 pm |
UNCLE-J
Joined: Fri Jul 24, 2009 7:26 am Posts: 10388 Location: S-Ville, LA
Wed Dec 08, 2010 12:42 pm |
chad454
stock pistons and stock rods. the work that is getting done to my stock heads involve. port, flow, polished, shaved.060, SS vavles that are being cut shortened and lightened, heavy duty push rods, shims under the springs and a 3 angle vavle job. And on the motor i have a cam, mikuni carb, and evt exhaust. before the heads i am getting 34.4 MPH at 4300 rpms on a 17x52 extreme GTB hull with a 12x10 prop with cup added. Two ppl loaded for hunting 32 MPH. so im very excited to see what speeds i run after i get my heads back and installed
Wed Dec 08, 2010 1:59 pm |
quackconsumer
Wed Dec 08, 2010 2:08 pm |
chad454
how would having heavy duty pushrods hurt or damage the engine?
Wed Dec 08, 2010 2:11 pm |
Jamie B.
you have to have a giving point that is where the stock pushrods work the best, or if something goes wrong you can mess up a lobe on the cam
Wed Dec 08, 2010 2:13 pm |
Jamie B.
dosent hoyt deck his heads .020 already with his stage II he puts out? If so are you going a additional .060 or just .040
Wed Dec 08, 2010 2:15 pm |
quackconsumer
Push rod are cheap and very easy to change out while on da water. If and when something decided to give dat is da best spot for da weakest point. Coondik has allready prove dis theory.
Wed Dec 08, 2010 2:19 pm |
chad454
i understand what your saying but if something happens to bend a pushrod then you are very lucky that this is all you messed up and typically will have lots more trouble to worry about than just changing a pushrod and goin ride somemore
Wed Dec 08, 2010 2:24 pm |
Jamie B.
Yes but a bent push rod in my experiences are caused by a split second over reving of Rpms, so with this the stock push rod bends and saves your cam lobes.
Wed Dec 08, 2010 2:41 pm |
latravcha
Just marking for later use
Wed Dec 08, 2010 2:44 pm |
cb5331
Wed Dec 08, 2010 3:36 pm |
Chico80x
Joined: Tue Aug 11, 2009 10:55 am Posts: 743 Location: Ft. Lauderdale, FL
What do you guys consider over reving? I know some of the higher end MB engines have the rev limit set a 5100 rpm but I don't think they run the factory push rods. I know my 5500 doesn't have the factory push rods in it and it has a rev limit of 4300 rpm.
_________________ "We Are Products Of Our Decisions"
Wed Dec 08, 2010 5:10 pm |
cb5331
I'm sure I will be corrected here if I'm wrong, but I want to say the stock rods fail somewhere in the neighborhood of 5000. Maybe 5500, but I think it was closer to 5.
Wed Dec 08, 2010 5:39 pm |
craig
Joined: Tue Jan 13, 2009 7:53 pm Posts: 7515 Location: Chauvin
_________________ 1750 GatorTail Extreme/Stage 3 37 GTR HD Procrastination is a lot like masturbation. Sure it sounds great at the time but, in the end your only f--k--g yourself.
Wed Dec 08, 2010 5:44 pm |
craig
Wed Dec 08, 2010 5:45 pm |
cb5331
Wed Dec 08, 2010 5:58 pm |
craig
Oh shit...my bad! Thought you was referring to connecting rods!
Wed Dec 08, 2010 6:13 pm |
cb5331
Well, we was talkin bout push rods weren't we?  I been studyin, can you tell?
Wed Dec 08, 2010 6:29 pm |
