| Need Modification Info!! http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=1452 |
| Author: | High Voltage [ Wed Apr 08, 2009 7:28 pm ] |
| Post subject: | Need Modification Info!! |
Brand new 35 Surface Drive on 18'X54" Surface Drive Boat runs 28.5 stock in deep water. What mods should I do without blowing it up? |
| Author: | dog walker [ Wed Apr 08, 2009 7:54 pm ] |
| Post subject: | Re: Need Modification Info!! |
Head work,carb,and exhaust .........nothing to it |
| Author: | hunter [ Thu Apr 09, 2009 5:36 am ] |
If you speak to Hoyt at Gatortail, he recommends head work,cam,pushrods,exhaust,carb replacment or he knows how to adjust factory carb. for maxium preformance. I am very happy with my modifications recommended by Hoyt. I replace my carb. and did the rest of the mods he recommended. I increased speed by 6mph and load carrying ability increased alot. Highly recommend! |
| Author: | deadbird8 [ Thu Apr 09, 2009 7:33 am ] |
| Author: | flatboat [ Wed Apr 15, 2009 10:21 am ] |
Your boat will never be fast you have the slowest boat/motor combo out there!!!!!!!!! |
| Author: | Divinduck [ Wed Apr 15, 2009 11:04 am ] |
| Author: | deadbird8 [ Wed Apr 15, 2009 4:07 pm ] |
I did alot of stuff to increase flow. Got most of the info here (and a lot of questions answered. I reduced the gear ratio to keep it under 4500RPM. -EVT Stage 1 heads -Old can style BPS exhaust (good high flow muffler) -K&N air filter -Bored out stock intake to combine the chambers and mate to the heads -Carb spacer -Thinned throttle shafts- replaced screw/lock washers on throttle/choke plates with low profile button head screws (loctite them in) -Cut the air intake plate -Trimmed the fan and removed screen mounting HW -Replaced the Gov Spring with one from the MB 45 -Valve lash at .005 Intake (Silk did this): Carb throttle shafts and low profile screws: Cut out intake plate to improve flow- smoothed out the elbow underneath too: Fan trimmed- probably minimal gain: It was a hot motor to start with pushing my heavy boat. |
| Author: | JD [ Thu Apr 16, 2009 10:38 pm ] |
| Author: | Divinduck [ Fri Apr 17, 2009 7:33 am ] |
| Author: | deadbird8 [ Fri Apr 17, 2009 11:49 am ] |
Probably could have kept the stock jets- have 148/150 in it now so not too much different. The MB 45 runs stock jets 142/148. Really need an exhaust gas analyzer to get it perfect. |
| Author: | Divinduck [ Fri Apr 17, 2009 1:09 pm ] |
| Author: | bayouboy [ Fri Apr 17, 2009 11:23 pm ] |
Good stuff! |
