BPS throttle handle help MB http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=14574 |
Author: | eazy89 [ Tue Dec 14, 2010 8:49 pm ] |
Post subject: | BPS throttle handle help MB |
Ok, I know Im a dumb ass for asking this but I dont want to mess anything up and not be able to get parts during duck season. How do I remove the old plastic throttle handle without cutting it or removing all the electronics in the control box? |
Author: | autogateman [ Tue Dec 14, 2010 8:53 pm ] |
Post subject: | Re: BPS throttle handle help MB |
are you talkin about a rubber grip? if so, shoot compressed air in from the back,it will loosen right up |
Author: | eazy89 [ Tue Dec 14, 2010 9:07 pm ] |
No, Im talking about the old plastic throttle control. |
Author: | DuckHunterF250 [ Tue Dec 14, 2010 9:11 pm ] |
buddy took his off and said he thinks it just pops off, prolly have to pry it apart if there isnt any screws |
Author: | shallow water master [ Tue Dec 14, 2010 10:50 pm ] |
there should be a set screw in it. to lock it in place |
Author: | take'emgator [ Tue Dec 14, 2010 11:29 pm ] |
WHy would you have to remove the wires in the control box? just wondering, the throttle should unscrew and then put a flat head in between the 2 and pop them apart |
Author: | deadbird8 [ Wed Dec 15, 2010 12:11 am ] |
If you are replacing it to put on the billet throttle lever then just cut it off (its plastic so a dremel or small saw will work to get good grooves in it and then just wedge a screwdriver in to break it through). If you are replacing the throttle lever you have to remove the football (4 screws), disconnect the wires, drill the rivets on the football support, spray some hair spray (or compressed air as posted above) to get the grip off and slide the new one on. |
