It is currently Fri Jan 30, 2026 8:34 am
Reply to topic  [ 4 posts ]
 Valve spring tension?
Post Valve spring tension?
I'm thinking of swapping out the stock springs and going with a set of doubles. I am wondering how much an aftermarket cam can handle on the lobes along with the rest of the valve train.
Thu Apr 09, 2009 3:48 pm
Post Re: Valve spring tension?
The stock rocker bolts are a weak link and can be stripped out very easily if tightened to much ( I think there is even a drastic misprint on the torque specs for those bolts in the service manual).
The double coils from EVT were pretty inexpensive and are easily installed by hand (at least, I did mine in a couple minutes by hand, with a rag stuffed under the chamber and a closed end wrench used to smash the springs down over the stems). Definately a good improvement over the stock springs.
Thu Apr 09, 2009 6:51 pm
ditto on da stock rocker bolts stripping...... put a heli-coil in mine last week.
Thu Apr 09, 2009 8:41 pm
Thanks RC, but I could have done without the rocker bolt info.
The more I get into these BB Briggs, the more I wish PD went with the Kohler.
Pasbon if you see this, get me the plate and stuff to swap over to the BB Kohler from the test rig in 07. ;)
Fri Apr 10, 2009 7:40 am
