It is currently Tue Jul 01, 2025 4:35 am
Reply to topic  [ 15 posts ]
 too cold! throttle cable frozen. any suggestions
Post too cold! throttle cable frozen. any suggestions
alright i went out saturday and monday morning and it was really cold, at least for ga it was probably 15 to 20 degrees. throttle cable was frozen i assume. it hasnt been acting sticky or anything. so i assume moisture has gotten in it at some point. just wonderinf if anybody has a good de-icer or non freezing lube they use or could suggest. thanks
p.s. already tried pouring hot coffee on it that only freed it enough to get stuck in the wide open position. it also wasted all my coffee
Thu Dec 16, 2010 9:23 am
Post Re: too cold! throttle cable frozen. any suggestions
Spray wd40 in cable and seal ends with grease.
Thu Dec 16, 2010 10:22 am
inject antifreeze aswell. it works.
Thu Dec 16, 2010 10:26 am
I've been working Rem Oil into mine.
MoMarsh Fatboy/2 Honda
Thu Dec 16, 2010 11:15 am
Don't do like me and get pissed off at it, kink the cable and dislodge it from the throttle lever....so its bitchin' cold, windy, dark, I'm early but will be late, and everyone will be in my spot first, and ya'll know how that might aggravate me even more.
Thu Dec 16, 2010 3:21 pm
Put yer face in the myrtles.
Thu Dec 16, 2010 5:54 pm
get one of these. they work awesome
http://www.denniskirk.com/jsp/product_c ... Id=&mmyId=
Thu Dec 16, 2010 5:56 pm
thought about wraping a copper wire around the exuhst and then around a bare part of the cable shield. thinkin it may ttransfer heat to the cable just dont know how much heat it will transfer or if it will be to much?
Thu Dec 16, 2010 7:32 pm
Anybody ever rigged a direct linkage like the pd on one of these other SD's?
[size=85][/size] Janky-ass Triton 1650 with an 06 PD frame, 09 PD LU, Generac slightly modded, Mikuni 42, and a bunch of bolts I found in a coffee can holding it all together.
Thu Dec 16, 2010 7:35 pm
1644 WeldCraft / 27 GDLT
Ranger R71 / 125 Merc
Thu Dec 16, 2010 7:58 pm
thats EXACTLY what i did
Fri Dec 17, 2010 7:14 am
well thats EXACTLY what i did ,plus got it stuck in full throttle so the ride back to the dock was interesting,not to mention cold
Fri Dec 17, 2010 7:19 am
Sun Dec 19, 2010 7:44 am
Is it just part of man's genetic make up to get pissed off at inanimate objects; its as though the throttle cable did it to you on purpose. I find myself calling inanimate objects by name and cursing at them: "You freaking throttle cable. You don't kink on my watch. I'll show you who's the boss 'round here"!
And, you, freaking decoys, what are you laughing at? If one of you SOBs decides to get tamgled you get the same from me."
Just sayin...
Sun Dec 19, 2010 11:40 am
Sun Dec 19, 2010 7:25 pm
Profile YIM
Users browsing this forum: No registered users and 181 guests
cron
