Not getting spark
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=14691
Author:  willett [ Sun Dec 19, 2010 3:48 pm ]
Post subject:  Not getting spark
Motor will turn over but won't fire off.
Getting plenty of fuel no problem
Changed spark plugs
Checked the plug wire with screwdriver from plug wire to motor and no spark on one side but tiny bit on other side.
Haven't taken the cowling off to look yet just tryin to figure out what it could be
Thanks in advance
Author:  willett [ Sun Dec 19, 2010 3:51 pm ]
Post subject:  Re: Not getting spark
It also cranked fine Friday but did notice it would act up when getting on the gas for take off but just thought that was carb issue
Would that have anything to do with ignition/spark problems?
Author:  craig [ Sun Dec 19, 2010 4:23 pm ]
Author:  deadbird8 [ Sun Dec 19, 2010 4:46 pm ]
You can check/eliminate the harness as a cause by taking off the cowling and disconnecting the spade connectors at the coils. You can then check spark on each side and then start the motor. If you have good spark and the motor starts, its the harness grounding out the coils. NOTE: YOU WILL NOT BE ABLE TO TURN THE MOTOR OFF WITH THE KEY OR KILL SWITCH (with the coil connections off)- choke it out or take off the spark plug wires to kill it (wear a glove). Depending on your motor there are several things that can ground the harness- kill switch, oil pressure switch, bad harness (insulation chaffed or bad diodes).
Author:  yknot [ Mon Dec 20, 2010 10:44 am ]
Dude, mine done the same to me on friday while out scouting, thought it was going to be a cold long wait for someone to get me. called a buddy and he told me to check rev limiter and shure enough two min latter i was on the prowl. unhook the green wire from the revlimiter if you have one and wire nut the engine side back off that should do you. Thats if you have a rev limiter on your engine. good luck with it.
Author:  willett [ Mon Dec 20, 2010 2:33 pm ]
did what u said gary and it cranked right up....any suggestions on where to start looking for the problem
I dont even know what a diode is or what it looks like
Author:  willett [ Mon Dec 20, 2010 2:42 pm ]
well i did what gary said then said what the heck ill try the rev limiter thing....i cut the green wire and bam started right up with the spade connectors on the coils
I couldnt turn the motor off but thats probably because all of my grounds were unhooked since the cowling is off
I'm gonna put everything back together and see if thats actually the problem
Or since I have it off and apart is it a good idea to go ahead and replace the coils and all that? or just wait til those actually go out?
Author:  willett [ Mon Dec 20, 2010 3:29 pm ]
put it all back together and it works like its supposed to so guess ill just get new rev limiter and the heck with the rest til it messes up
i hate it but glad when its something simple lol
thanks for the help guys
Author:  deadbird8 [ Tue Dec 21, 2010 2:37 am ]
SOrry, didn't know you had a rev limiter on it. I would always put a spade connector on the green wire to eliminate the rev limiter quickly if there was a problem. Something was grounding your coils (on a Briggs there is lots that hang off that circuit- Key switch (to turn off), Kill Switch, oil pressure solenoid (if installed), Rev Limiter (if installed)). Sounds like you found the source.
I install rev limiters in the rear box to protect them (just extend the wires).
Author:  BROOKS [ Tue Dec 21, 2010 1:59 pm ]
DeadByrd8s ~ You gots good knowledge 'bout thangs and I'm proud you 'round MMT ....
Thanks to you and I hopes you have a Merry Christmas !!! :D
Author:  deadbird8 [ Tue Dec 21, 2010 5:42 pm ]
You have a wonderful holiday Mr. Brooks! One of these days I will chase these duckbyrds East and will run across you @ a ramp.
