kill switch http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=14854 |
Author: | med [ Sat Dec 25, 2010 11:06 am ] |
Post subject: | kill switch |
just found that my kill switch is not working but it was a while back. the conections look good and tight tho. anyone know how to trouble shoot this or what i need to try to get it working? do these usually go bad and stop working or is it most likely a bad connection? i run some bad stumps and i have to get it working. thanks |
Author: | garjacker [ Sat Dec 25, 2010 11:37 am ] |
Post subject: | Re: kill switch |
are you talking terminal kill switch with the laynyard or your ignition switch? |
Author: | deadbird8 [ Sat Dec 25, 2010 8:21 pm ] |
I have seen the switches go bad and not allow it to start, but most of the time it goes bad and doesn't. Replace the switch. Call BoatDr Med, he will get it out quick. |
Author: | HUNT4DEER [ Sun Dec 26, 2010 8:48 am ] |
the kill switch grounds out the ignition. when the switch is in place it opens the circuit, no ground. when pulled it closes the circuit and kills the ignition. ide check the switch to make sure it is moving when pulled. if its seems to be working, moving, i would trace the wires and make sure the lead in is connected to the ignition and the other is getting a good ground. the wire from the ignition should have a connector. you can ground it out at that point and it should shut the motor down. if not, something has come loose up in the ignition. if it does you can check the switch with an ohm metter. hook it up to the wires in and out of the switch and cycle the switch, you should see the circuit open and close. if not its the switch. of all that i listed ide bet its where the switch is grounded. either a broken wire or loss of ground. but if you try the above you will fine it. |
Author: | med [ Sun Dec 26, 2010 7:20 pm ] |
ok. thanks guys. will check that in the am. a few months ago i checked it and it was fine. the other morning i needed to shut down quick so i just pulled the lanyard loose but the bastard kept running. i pulled the clip and that deal goes in like its supposed to. hopefully ill be able to fix it. |
Author: | med [ Tue Dec 28, 2010 1:48 pm ] |
1/2 turn to tighten the ground did the trick. thanks all. |
Author: | brianb [ Tue Dec 28, 2010 5:57 pm ] |
what type of speed do you get with the 23hp long tail and the 16 44 boat 1-2 and 3 people etc thanks |
