It is currently Thu Jul 03, 2025 5:01 pm
Reply to topic  [ 9 posts ]
 Generac Mods
Post Generac Mods
Cracked the block on my stage 1 Briggs. Have a Generac 40 on the way. Maybe I'm crazy for wanting to mod another motor , but I just need a little more get up and go for my big ol barge 2054.
I'm thinking of advancing the timings, carb, exhaust, deck the heads, shim the valve springs. Considering a cam. For the guys that have a little experience with the generac, would these mods be somewhat reliable? Any other thoughts or suggestions would be appreciated.
WC Custom 1854
Sat Jan 01, 2011 6:44 pm
Post Re: Generac Mods
Get a mikuni, change over to the stock natural gas pistons (flat tops), advance the timing but find a way to lock it in as the flywheel will slip as advance keys are not readily available, leave the stock cam in it... and leave the heads alone as the combustion chamber is already pretty small 9:1 compression stock motor so the flat tops will put you as far as you want to go in my opinion... Robert at EVT did mine so I can only speak from the outside since I did not see the internals go in... I think you will be happy with that... Stage 2 power in a stronger block... more power than you think at only 4000rpm...
They are a very smooth running motor at 4000rpm.... wont shake ya to death like a Briggs
Sat Jan 01, 2011 7:16 pm
WC Custom 1854
Sat Jan 01, 2011 7:28 pm
Do the connecting rods need to be switched out if the flat top pistons are done? Also, would it then be a good idea to beef up the valves to a one piece stainless and better push rods?
WC Custom 1854
Sun Jan 02, 2011 11:16 am
crap Adam!!! how many hours did you get out of it?
just drag it to PD and tell them you need duals and be happy!!!
Mon Jan 03, 2011 3:53 pm
Motor is shipped after getting raped by ups :o
20x60 homemade with twin Prodrives
JH Chopper (YLM)if I have time will make a SH
Mon Jan 03, 2011 4:33 pm
WC Custom 1854
Mon Jan 03, 2011 5:57 pm
After speaking with Mike at evt, we have agreed the following recipe should work best for my needs.
Port/Polish the heads , No decking
Stainless Valves, shim the valve springs.
Mikuni 42mm Carb with evt adapter, mod the intake.
High Flow Exhuast
Advance the timing
Lock out the governer and install Rev Limiter
Motor already has flat top pistons installed. Hopefully this will give me years of dependable service (yeah, right :lol: )
WC Custom 1854
Tue Jan 04, 2011 4:10 pm
I sent you a curcio carb adapter lol :lol:
Tue Jan 04, 2011 4:14 pm
Users browsing this forum: No registered users and 136 guests
