It is currently Wed Jul 02, 2025 6:41 am
Reply to topic  [ 6 posts ]
 Kholer 25 Mods
Post Kholer 25 Mods
I have a Kholer 25 Go Devil Longtail and would like to get a few mods for it. Can anyone give me a few ideas what and where to get upgrades?
I really would like SS Dual exhaust asap. How makes them, how much, and are they easy to install?
Thanks Everyone!
Jeff
Team Total ASalt
Mossy Oak Pro Staff
1854Gator Traxs w/HD pushed by a MB 5000.
Ams wrote:
If assholes could fly this place would be an airport
Tue Jan 11, 2011 12:02 pm
Post Re: Kholer 25 Mods
Better off saving your money to buy a bigger motor, but...
The parts off the 30 kohler will fit. You can get the heads/intake/carb and you will see some better performance. Not gonna gain much speed, but should help out a lot with a load.
Other option is to pull your heads, take them to a machine shop and have them shaved .030-.045. I have a guy locally that will do this for about 100 bucks. Anywhere 100-175 or so would be normal. Have them check your valve seats also, and do a valve job while your in there if needed. Valve job is probably another 100 bucks. Stock valves and seats are usually okay on the kohlers but def have the machine shop check everything while they have it.
Another option on the carb is a mikuni. I have had a bunch of trouble trying to tune mine, but if you know what you are doing that is an option. The 30 carb is a lil more straight forward. Bolt it on and it's pretty much set and ready to go.
As far as exhaust, Mud Buddy is your only option. It's not a dual set up, but the single's flow better than duals anyway. Give Keith at setx performance a shout and he can hook you up. If you can't find anyone local, he may be able to help with the head work also.
www.Extremevtwins.com is another place that can help you out. Also Julian at www.midwestsupercub.net
Good luck.
Tue Jan 11, 2011 1:16 pm
If you want duals, you're better off buying some bike pipes and fab'n up your own.
Geaux 1848, 32PD w/stage III case gasket and decked valve covers
Tue Jan 11, 2011 2:56 pm
Thanks CB for your insite!!
Would I get any extra HP with duals over Mud Buddy Kohler SS Exhaust? I can have Duals fab'd but I wouldn't if there was no extra HP with it. I do think they look great so ..........
Team Total ASalt
Mossy Oak Pro Staff
Tue Jan 11, 2011 3:49 pm
I once had a 27 kohler that I was gonna mod. I now have a 30 kohler. The intake is much larger, the carb is bigger, and the heads have a much smaller combustion chamber. If it were me... I would have your factory heads reworked a little, get a mikuni and a 30hp intake, and put some sort of aftermarket exhaust on it. Just be carefull with the heads, you can't shave very much at all off of them due to the hydraulic lifters.
Tue Jan 11, 2011 4:25 pm
Tue Jan 11, 2011 6:17 pm
Users browsing this forum: No registered users and 80 guests
