Anyone ever loose the rotating screen while running? http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=15388 |
Author: | SP [ Sun Jan 16, 2011 9:22 pm ] |
Post subject: | Anyone ever loose the rotating screen while running? |
I was hunting on Saturday, and after a cluster of a morning- my buddies battery was dead at the ramp as I am waiting for him already in the water- changed his battery- turned out his clutch was engaged! ![]() ![]() ![]() Has this ever happened to anybody? Just curious. I have already ordered a new screen and screws from Briggs. |
Author: | POKER1 [ Sun Jan 16, 2011 9:30 pm ] |
Post subject: | Re: Anyone ever loose the rotating screen while running? |
It has happened to a few folks. Thats why some of us have taken it off. Its not needed in this application. |
Author: | SP [ Sun Jan 16, 2011 9:40 pm ] |
I was kind of thinking the same thing, but I will probably put it back on. It is a pretty easy fix on the water. I was just surprised to see it give way. Is it from over tightening the screws, bending the screen, and making it weaker? I have about 145 hrs on the motor. Or is it just a weak link that eventually goes? |
Author: | craig [ Sun Jan 16, 2011 9:43 pm ] |
Leave it off.... |
Author: | POKER1 [ Sun Jan 16, 2011 9:47 pm ] |
I think it can cause other damage when it comes loose. Probably just metal fatigue and the light weight screen being easy to pull loose. |
Author: | SP [ Sun Jan 16, 2011 10:03 pm ] |
You are right- it certainly could if it actually cracks and pieces come loose and drop into the motor.... Sounds like I should have saved the 32 bucks! |
Author: | deadbird8 [ Sun Jan 16, 2011 11:07 pm ] |
Trim the fan blades about a 1/4 inch, get rid of the HW and tie it to the cowling: |
Author: | JBREAUX [ Mon Jan 17, 2011 12:12 am ] |
Happened to me, running wide open. It sounded BAD! it ended up cutting the grounds to the coils and breaking a few fan blades. It made for an interesting weekend of hunting, motor wouldnt turn off with the key, plug wires will shock you pretty good. I would not put it back on. |
Author: | keestan31 [ Mon Jan 17, 2011 7:45 am ] |
It happened to me about 3 weeks ago...I am not putting it back on. You talk about a sh!tty sound to hear when your trying to get to your spot. |
Author: | UNCLE-J [ Mon Jan 17, 2011 7:52 am ] |
Most people that mod engines, leave that screen off. So, you should be good without it. |
Author: | SP [ Mon Jan 17, 2011 9:29 am ] |
I will take a look at that option DB. It looks like from the picture the set up is a little different on the PD, but I am sure I could make that work. I like the idea of having the screen on, especially on a PD, to stop acorns or whatever from falling into the motor. With a MB/GTR, that is not as likely, but with a PD...not so sure. |
Author: | SP [ Mon Jan 17, 2011 12:29 pm ] |
Author: | deadbird8 [ Mon Jan 17, 2011 7:26 pm ] |
Author: | keestan31 [ Tue Jan 18, 2011 8:01 am ] |
Author: | UNCLE-J [ Tue Jan 18, 2011 8:34 am ] |
Author: | keestan31 [ Tue Jan 18, 2011 10:49 am ] |
well some how one of the bolts jammed in my starter...luckily I had to tools and some help with me and we pulled the starter un jammed it put it back on, got all of the other crap out of the flywheel and we were back on our way. I havent noticed any difference with half of my fins missing so I guess it wont hurt anything. |
Author: | take'emgator [ Tue Jan 18, 2011 11:03 am ] |
Thats it im pulling mine off when i get home that stuff aint happening to me |
Author: | deadbird8 [ Tue Jan 18, 2011 8:46 pm ] |
