It is currently Wed Jul 02, 2025 12:43 am
[ 5 posts ] |
32 PD fuel pump replacement?
shooter
Owners manual shows this as P/N 842920, but this part doesn't seem to be available anymore. I can't find a replacement callout online. Is there a mechanical replacement available? If I go with an electric pump, what is recommended?
_________________ 32 PD with EVT cam, decked heads, shaved pistons and not enough sense to leave things alone!
Tue Jan 25, 2011 9:23 pm |
Chico80x
Joined: Tue Aug 11, 2009 10:55 am Posts: 743 Location: Ft. Lauderdale, FL
 Re: 32 PD fuel pump replacement?
Get a Facet cube pump with about 1.5-3 psi of pressure and you're good to go. http://www.facet-purolator.com/index.ph ... &Itemid=31These are solid state pumps that are supposed to be very reliable. They're even used in some airplanes. I've been using the 40104 and haven't had any issues with it over flowing my carbs and if you're going to mount it far away from the tank, get one with a check valve.
_________________ "We Are Products Of Our Decisions"
Thu Jan 27, 2011 8:41 pm |
shooter
Thu Jan 27, 2011 9:51 pm |
Chico80x
I have a custom aluminum fuel tank under my extended front decK and had them weld a bracket for the pump on top of it. I also powered the pump through the key switch. I think the E fuel pumps are much better than the mechanicals.
Thu Jan 27, 2011 10:29 pm |
Chico80x
Napa carries Facet pumps.
Thu Jan 27, 2011 10:30 pm |
[ 5 posts ] |
Users browsing this forum: No registered users and 120 guests |
