It is currently Tue Jul 01, 2025 5:52 pm
Reply to topic  [ 5 posts ]
 32 PD fuel pump replacement?
Post 32 PD fuel pump replacement?
Owners manual shows this as P/N 842920, but this part doesn't seem to be available anymore. I can't find a replacement callout online. Is there a mechanical replacement available? If I go with an electric pump, what is recommended?
32 PD with EVT cam, decked heads, shaved pistons and not enough sense to leave things alone!
Tue Jan 25, 2011 9:23 pm
Post Re: 32 PD fuel pump replacement?
Get a Facet cube pump with about 1.5-3 psi of pressure and you're good to go.
http://www.facet-purolator.com/index.ph ... &Itemid=31
These are solid state pumps that are supposed to be very reliable. They're even used in some airplanes. I've been using the 40104 and haven't had any issues with it over flowing my carbs and if you're going to mount it far away from the tank, get one with a check valve.
"We Are Products Of Our Decisions"
Gator Trax 1750HD With Mud Buddy Black Death 5500
Thu Jan 27, 2011 8:41 pm
Thu Jan 27, 2011 9:51 pm
I have a custom aluminum fuel tank under my extended front decK and had them weld a bracket for the pump on top of it. I also powered the pump through the key switch. I think the E fuel pumps are much better than the mechanicals.
Thu Jan 27, 2011 10:29 pm
Napa carries Facet pumps.
Thu Jan 27, 2011 10:30 pm
Users browsing this forum: Dmuise18 and 196 guests
