It is currently Thu Jul 03, 2025 3:01 am
[ 5 posts ] |
Engine Dying off idle....
SP
Not all of the time, but it kept happening this morning while I was hunting. It would die sometimes at idle, but if I engaged the clutch after a prolonged idle it would die immediately. I played with the air mixture screw on the water and it seemed to help. I then dialed in the air screw when I got home tonight. Seems it is best at 2 turns out. I am hunting again in the AM, so I am not sure if the same problem will materialize (it does not happen out of the water).
Why would a motor die when the clutch was engaged?
Sat Jan 29, 2011 5:41 pm |
cb5331
 Re: Engine Dying off idle....
Any more than two turns out, I think you want to go to a bigger pilot. I'm not a guru, but what size do you have in there now? Do you have a larger one to try? If you are at two turns now, your right on the brink...
Choke isn't sticking? Float is adjusted properly? No air leaks? All I can think of, but that's some stuff to play with.
Sat Jan 29, 2011 5:58 pm |
SP
Cool thx man- pilot is a 25- no leaks- choke is good- float tab is adjusted. It just started today. I had the boat in a briggs repair center to check my heads, after a compression check set off a couple alarms...long story...I know he found a couple of screws in the intake that were tight, but not bottomed. He fixed those- so i am thinking I might have had a leak before and now that it is fixed, the sir mixture was off- this was just my thinking...but what do I know. I guess I will find out tomorrow.
Sat Jan 29, 2011 6:25 pm |
craig
Joined: Tue Jan 13, 2009 7:53 pm Posts: 7515 Location: Chauvin
What rpm does the engine idle at? Where you located?
_________________ 1750 GatorTail Extreme/Stage 3 37 GTR HD Procrastination is a lot like masturbation. Sure it sounds great at the time but, in the end your only f--k--g yourself.
Sat Jan 29, 2011 6:32 pm |
SP
Sun Jan 30, 2011 3:32 pm |
[ 5 posts ] |
Users browsing this forum: No registered users and 112 guests |
