It is currently Mon Oct 19, 2026 8:10 am
Reply to topic  [ 18 posts ]
 decking heads
Post decking heads
how much to deck the heads? I hear everything from 0.020-0.050
When in doubt, throttle out.
18x60 prodrive w/36 prodrive
Tue Feb 01, 2011 5:17 pm
Post Re: decking heads
Leave them alone, do carb and exhaust
Tue Feb 01, 2011 5:19 pm
Tue Feb 01, 2011 5:20 pm
oh ok
Tue Feb 01, 2011 5:26 pm
Tue Feb 01, 2011 5:27 pm
going with SS valves with valve job, and springs are already shimmed.
Tue Feb 01, 2011 5:37 pm
Does anybody have a source for stock size stainless valves?
Tue Feb 01, 2011 5:49 pm
X2.....
If I can't Break it, it can't be Broke.............................
Tue Feb 01, 2011 5:52 pm
What is shimmig and why does one do it? I'm thinking the decked heads shorten the distance between the stem and the rocker so one has to make up that distance by placing a washer to bring the spring and thus the rocker closer to the stem to return the spacing back to factory spec. I still not sure where the shim is inserted, however. Am I close?
Tue Feb 01, 2011 5:54 pm
Tue Feb 01, 2011 6:04 pm
Tue Feb 01, 2011 6:05 pm
So one can shim a valve or a valve spring, but its the later of which one does after decking heads. Correct?
Tue Feb 01, 2011 6:34 pm
18x54 WC custom
36PD EFI
Tue Feb 01, 2011 6:40 pm
Tue Feb 01, 2011 6:43 pm
u shim ur springs to give u more spring tension so u can turn more rpm's before u float ur valves u can do it with or without shaving ur heads!!!!!!
Tue Feb 01, 2011 6:44 pm
Wed Feb 02, 2011 5:51 am
Wed Feb 02, 2011 8:30 am
Hard to keep those seats from warping. Best to actualy get older heads with run time on them then recur seats and lap in stainless valves. The valves we use are stock size.
Wed Feb 02, 2011 5:03 pm
