It is currently Sun Oct 18, 2026 5:16 am
Reply to topic  [ 4 posts ]
 2009 36 pd fpr 250 hrs.....what do i need to do?
Post 2009 36 pd fpr 250 hrs.....what do i need to do?
Regular maintenance has been performed, but wondering if their is anything else that needs to be changed, checked, adjusted...whatever. motor runs great...starts right away, runs about 4180rpm in neutral and 4080 w 2 people at 27 mph....i know i need a new prop, about 3/4" misiing. also lower unit? anything need done on that with this many hours?
Black ops IITX marshstalker
1840 WC www.wccustomboats.com
fuel injected 25 GTR
Thu Feb 03, 2011 9:54 am
Post Re: 2009 36 pd fpr 250 hrs.....what do i need to do?
PD has the manual posted online for the lower unit maintenence.
For the motor, if you don't have one already, order the service manual. Not too much to check on it though as far as regular maintence. Valve clearance, spark plugs, oil, air filter, and oil filter. If it's running good, I wouldn't mess with cleaning the carb...
Thu Feb 03, 2011 10:31 am
Ive got both manuals, just wondering what I need to be on the lookout for. Like I said, there are no problems, motor purrs, trim has moisture problems but I am deailing with that. replaced ignition and put in an inline fuse to protect wiring harness..........
Planning on a stage one kit when I rebuild engine but running too good to mess with....if it aint broke dont fix it.....
Thu Feb 03, 2011 11:34 am
Turn your rpms back up to 4300 in neutral.
Thu Feb 03, 2011 1:41 pm
