Found 2 oil leaks. What do they mean?
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=15783
Author:  bbb [ Wed Feb 02, 2011 1:33 pm ]
Post subject:  Found 2 oil leaks. What do they mean?
2010 Vanguard 35 CDI with Mikuni Carb and MM muffler.
Found this oil coming out of the Mikuni Carb.
Found this dark colored oil coming from the block. Leaky gasket?
Checked the oil level and it was between Add and Full.
Motor runs fine for the most part. Have noticed that anything past 3/4 throttle, and the motor tends to slow down.
Author:  donlegen [ Wed Feb 02, 2011 1:37 pm ]
Post subject:  Re: Found 2 oil leaks. What do they mean?
IDK about the first one, but the second is the crankcase gasket. Mind is being changed now, and from what I am told they all do this in the same spot.
Author:  darrel from meraux [ Wed Feb 02, 2011 1:52 pm ]
If the first is coming out fo the mikuni then it's not an oil leak. No oil is circulated through a carbertor. Iv seen them before with a dark rust colored gel coming out of them which is just varnished gas. Probably a bad seal on the carb.
Author:  craig [ Wed Feb 02, 2011 2:35 pm ]
Author:  craig [ Wed Feb 02, 2011 3:02 pm ]
BBB....if the oil is indeed coming from the carb. your reed valve may need to be adjusted...or try running some thicker oil.
The other pic of your crankcase gasket leaking is a continous problem with all big block Briggs engines...
Author:  bbb [ Wed Feb 02, 2011 5:28 pm ]
That's good to hear guys.
I'm about to change to Amsoil, and if it keeps this up, I'll have someone with more experience check out my carb.
Author:  50fps [ Wed Feb 02, 2011 6:45 pm ]
In the top photo you have a fuel pump block off plate. Are you sure the oil isn't from that area?
Author:  shallow water master [ Wed Feb 02, 2011 8:17 pm ]
Author:  Chico80x [ Wed Feb 02, 2011 9:27 pm ]
Author:  craig [ Wed Feb 02, 2011 10:15 pm ]
Author:  Chico80x [ Wed Feb 02, 2011 10:38 pm ]
Author:  take'emgator [ Wed Feb 02, 2011 10:45 pm ]
Author:  pokey79 [ Thu Feb 03, 2011 8:06 am ]
on the parts list the box on side of the valve cover is a breather reed!!!!
Author:  craig [ Thu Feb 03, 2011 8:20 am ]
Author:  OwenDickeson [ Thu Feb 03, 2011 8:45 am ]
Author:  bbb [ Thu Feb 03, 2011 2:22 pm ]
