It is currently Mon Oct 19, 2026 10:29 am
[ 8 posts ] |
50fps
 Pulled threads!!!
Went and pulled the heads off today and the threads in my block decided they've had enough and will no longer accept full torque.
Any good remedies short of a new bare block?
I am leaning toward using heli-coils and studs epoxied in permanently.
| Sat Feb 05, 2011 7:45 pm |
muddiejeep
Joined: Tue Jan 13, 2009 6:24 pm Posts: 761 Location: New Orleans, LA.
 Re: Pulled threads!!!
I don't know if you can, but can you drill and tap to the next bigger size?
_________________ When in doubt, throttle out. 18x60 prodrive w/36 prodrive
| Sat Feb 05, 2011 7:58 pm |
kibb
Either way, they will have to be drilled and retapped. Assuming you will go back with the same stud size when using the helicoil. If you can I would go the helicoil route but forget the epoxy.
| Sat Feb 05, 2011 8:14 pm |
Tenpoint
Joined: Thu Aug 27, 2009 5:22 pm Posts: 2029 Location: Patterson LA
Either helicoil or tapping to the next size up will be alot cheaper than a new block. Anything is repairable. Ive seen v6 Mercury blocks get broke in half due to broken cranks and believe it or not, get welded back together and re-sleeved and be like new in no time.
_________________ 19x48 Rink/Aucoin Bateau w/35 GTR 20x60 Home-made skiff w/200 Merc
| Sat Feb 05, 2011 8:23 pm |
muddawgchuck
Joined: Fri Oct 01, 2010 9:22 pm Posts: 959 Location: Spurger Tx.
http://www.timesert.com/ Give something like this a try we use something similar at work alot and they seem to work very well.
_________________ 18x54 WC custom 36PD EFI
| Sat Feb 05, 2011 8:29 pm |
muddawgchuck
Jergens brand are the ones we use
| Sat Feb 05, 2011 8:30 pm |
50fps
Briggs is running M9 bolts, and studs are a bitch to find in a 80mm+ length for them.
M10 studs are readily available, so long as there is enough material to work with.
I believe what did the threads in was the repetitive swapping of different head configurations for testing.
| Sat Feb 05, 2011 8:36 pm |
mason85
| Sun Feb 06, 2011 3:33 am |
[ 8 posts ] |
