scary noises http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=16129 |
Author: | garrettpearce [ Sun Feb 13, 2011 9:52 pm ] |
Post subject: | scary noises |
i have a stage 1 with evt 493f cam and at 2000 rpm's my motor has a knocking noise. is it just something they do or what? |
Author: | Woodiebuster [ Sun Feb 13, 2011 9:56 pm ] |
Post subject: | Re: scary noises |
Rod knocking? |
Author: | garrettpearce [ Sun Feb 13, 2011 10:02 pm ] |
i dont think so it doesnt do it at idle or after 2400 rpm im not sure what it is. ive heard of something called a timing knock,any input on that. |
Author: | SMELVIN [ Sun Feb 13, 2011 10:18 pm ] |
didnt you say you had a timing key in it ? you might have to much or not enough. might be that rpm range on the cam? |
Author: | garrettpearce [ Sun Feb 13, 2011 10:20 pm ] |
thats what im thinking. if someone with a 493 reads this please input |
Author: | cb5331 [ Sun Feb 13, 2011 10:20 pm ] |
You tried calling Mike? |
Author: | garrettpearce [ Sun Feb 13, 2011 10:22 pm ] |
no, is that evt? |
Author: | SMELVIN [ Sun Feb 13, 2011 10:23 pm ] |
if a mm cam is anything like a car cam its going to have an operating range where your going to get all your HP at certain rpm's. that might be the low end of the range |
Author: | garrettpearce [ Sun Feb 13, 2011 10:25 pm ] |
yea its hard to explain it, its not rodsor bearings its almost sounds like its coming fro the flywheel maybe power band.idk |
Author: | cb5331 [ Sun Feb 13, 2011 10:28 pm ] |
Author: | garrettpearce [ Sun Feb 13, 2011 10:30 pm ] |
got cam from a friend and everything else bps, but will def call him. dont rememberit doing that with hoyt cam but also didnt have timing key. |
Author: | take'emgator [ Sun Feb 13, 2011 10:36 pm ] |
Hey Garrett jsut squeeze the throttle and have fun hahahahahaha |
Author: | garrettpearce [ Sun Feb 13, 2011 10:37 pm ] |
thats what ive been doing and works so far but trying to make it to tx. lol |
Author: | take'emgator [ Sun Feb 13, 2011 10:39 pm ] |
Put it in the garage and wait till the 25th-27th to pull it out and run it |
Author: | garrettpearce [ Sun Feb 13, 2011 10:40 pm ] |
wont work so well im an addict. |
Author: | deadbird8 [ Mon Feb 14, 2011 4:32 am ] |
is it a CDI motor? |
Author: | garrettpearce [ Mon Feb 14, 2011 8:15 am ] |
No |
Author: | craig [ Mon Feb 14, 2011 8:22 am ] |
Some engines do that....My engine has always done it. It doesn't do it near as bad if I run premium gasoline. It almost sounds like detonation....if your already running good gas don't worry about it. |
Author: | deadbird8 [ Mon Feb 14, 2011 8:32 am ] |
Author: | drake1 [ Mon Feb 14, 2011 9:43 am ] |
What timing key did you put in it? At the most with that cam you would want a #5 with premo gas. we do not put nothing bigger than a #3 in the 35 and a #5 in the 31. It did not do with the bigger cam do to the compression was being bled off from the longer duration and is a top end cam. |
Author: | garrettpearce [ Mon Feb 14, 2011 12:31 pm ] |
I have # 3 |
Author: | deltaduckmaster [ Mon Feb 14, 2011 5:59 pm ] |
That their noise is the ticking on the bomb!! ![]() |
Author: | shallow water master [ Mon Feb 14, 2011 6:54 pm ] |
Author: | garrettpearce [ Mon Feb 14, 2011 9:28 pm ] |
na men, got to have faith. |
