BASSMASTER
Joined: Thu Jul 22, 2010 12:55 pm Posts: 1091 Location: TX
 on/ off electric fuel pump
is there any way to wire in a fuel pump thats in your gas line to the motor. so it turns on and off with the motor ?
i thought bout on the out side of the ignition, will that work?
_________________ Gave up hunting ducks and started underwater basket weaving!
Mon Feb 14, 2011 9:26 am |
latravcha
 Re: on/ off electric fuel pump
I did mine this weekend Find a wire on the harness using your meter that is hot when the key is on. I think i used one of the purple wires coming off the harness for the prodrive.
_________________ Aucoin 20X48 36pd Lock your wife and your dog in the garage for an hour. Then open it and see who's happy to see you.
Mon Feb 14, 2011 9:47 am |
BASSMASTER
thanks, what psi is your pump pushing?
Mon Feb 14, 2011 10:15 am |
latravcha
i think it is a 1.5 to 2.5 psi got it from carquest for about 45$
Mon Feb 14, 2011 10:23 am |
BASSMASTER
the range on mine is 2 - 3.5 hopefully there's an adjustment kob to turn it down. mine was 46 + tax from advance auto parts
Mon Feb 14, 2011 10:53 am |
latravcha
there is no adjustment that I know of I dont think you will have any problems with it Just make sure you use the filter it comes with or put it after your filter/water seperator I left the primer bulb on mine just incase the elec. pump went out
Mon Feb 14, 2011 11:06 am |
BASSMASTER
i was gonna ask if you had to take the primer bulb out.
Mon Feb 14, 2011 11:28 am |
Chico80x
Joined: Tue Aug 11, 2009 10:55 am Posts: 743 Location: Ft. Lauderdale, FL
I took my primer bulb out but I carry a spare pump just in case. Some of the guys on here recommend that you take the primer bulb out since you really won't use it and it can create more problems than it will solve.
_________________ "We Are Products Of Our Decisions"
Mon Feb 14, 2011 11:39 am |
BASSMASTER
i'm probably gonna take it out, i could see it gettin in the way!
Mon Feb 14, 2011 11:59 am |
garrettpearce
Joined: Mon Jul 27, 2009 8:10 pm Posts: 1436 Location: down da bayou
I hooked mine to the red wire on the back of ignition
Mon Feb 14, 2011 2:09 pm |
BASSMASTER
is yalls marine grade ? mines not, hope it'll last getting a lil damp. its gonna be in a dry place just don't know how durable these fkers are.
Mon Feb 14, 2011 2:12 pm |
latravcha
I bought a facet had the same thing on my airboat and ran it for several years without a problem I would not worry about it
Mon Feb 14, 2011 2:23 pm |
BASSMASTER
thanks man, gonna install tom.. hopefully it works.
Mon Feb 14, 2011 2:39 pm |
cb5331
Mon Feb 14, 2011 2:43 pm |
BASSMASTER
we'll i can fix pretty much anything else besides motors... so wiring and connect a few lil hoses in no biggie.
ya its dying on me when i run wfo unless i sit there and pump the bulb!
Mon Feb 14, 2011 2:48 pm |
cb5331
I'se jus messin... The pump will probably fix you up. Probably just a small air leak somewhere, but sometimes adding a pump is easier than tracking it down.
Mon Feb 14, 2011 2:52 pm |
BASSMASTER
ya i'm sure there is all kinda air leaks! i'm prob gonna redo all the gas line that way i don't have any excuses y my shat keeps dying lol.
Mon Feb 14, 2011 3:01 pm |
Chico80x
A big X2 on getting a Facet. I learned about them on this site and after researching them a bit, they've proven themselves reliable. I put 47 hours on one this season and only had one issue with it when it lost it's prime. So I had to disconnect the fuel hose going into the engine and let the pump run a bit. I also think this happened because I didn't let the pump prime the fuel lines before starting the engine that day and I think this had something to do with it.
Mon Feb 14, 2011 4:18 pm |
BASSMASTER
so when i turn the key on let it prime for what 30 seconds to a min?
Mon Feb 14, 2011 4:44 pm |
Chico80x
You can hear when the pump gets primed on a Facet. When you start it, it'll rattle a bit then become silent once fuel pressure builds up. Usually takes about 3-5 seconds and you're good to go. The only time I didn't do this and decided to start the boat in the water and take off is also the only time it lost prime and I couldn't get the engine started again.
This might be speculation but, I'm willing to bet that throttle response is also better with an E fuel pump than the stock one. My thinking is that the fuel is always under pressure regardless of what RPM the engine is at. So when you hit the gas coming from a stand still, the pressurized fuel really helps get things going. Just my guess though.
Mon Feb 14, 2011 6:24 pm |
take'emgator
Joined: Mon Oct 19, 2009 6:38 pm Posts: 10201 Location: SETX
X2 on the faucet, got mine and ain't looked back
Mon Feb 14, 2011 6:48 pm |
chad454
when putting a E-pump do you need to reroute the fuel line to bypass the mechanical fuel pump or leave in on?
_________________ 17x52 x-treme with 35-GTR Stage 2.25
Tue Feb 15, 2011 11:54 am |
BASSMASTER
leave it
Tue Feb 15, 2011 12:03 pm |
garjacker
Joined: Sat Oct 17, 2009 3:39 pm Posts: 321 Location: greensboro n.c.
yea i e-pump both of mine, i use the facet 40177 1-2 psi. i also use the duel shut off kill switch that Sea Choice offers. its a normal open and normal closed switch. so with clip in, my terminal kill is open and i use the normal closed on the ground side of e-pump, that way if i pull the cord the engine dies and the fuel pump shuts off.
Tue Feb 15, 2011 6:56 pm |
Chico80x
I have a MB 5500 that came with an e pump from factory and it has the cover on it where the fuel pump goes. If you're going to go the E pump route, I would bypass the stock fuel pump all together just to avoid any issues that might develop.
Tue Feb 15, 2011 8:06 pm |
BASSMASTER
ok just installed the pump,, its coming on but no fuel is coming into the filter , how long should it take to pull a vacuum
Tue Feb 15, 2011 9:18 pm |
Chico80x
It'll take a while to fill up the filter, just make sure you run it with the hose going into the engine disconnected and it should fill up in a minute or so.
Also, if you bought a Facet, make sure it's mounted close to the tank preferably below it. I have mine mounted right on top of the tank and haven't had any issues with it pulling fuel out.
Tue Feb 15, 2011 9:23 pm |
take'emgator
unhook the hose and let it run till you see fuel, then hook it up
Tue Feb 15, 2011 9:26 pm |
BASSMASTER
copy that , got it workin thanks fellas
Tue Feb 15, 2011 9:52 pm |
