ProDrive Vibration http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=16155 |
Author: | stonewall65 [ Mon Feb 14, 2011 3:32 pm ] |
Post subject: | ProDrive Vibration |
How much felt vibration is normal for a PD36? I bought a used lower unit and repowered, and although everything looks to be running straight, after 10 minutes at 3500RPM my arm starts to get numb from the vibration. |
Author: | Woodiebuster [ Mon Feb 14, 2011 3:56 pm ] |
Post subject: | Re: ProDrive Vibration |
Unbalanced prop? |
Author: | POKER1 [ Mon Feb 14, 2011 6:14 pm ] |
Corpal tunnel? Hits me hard with the twist grip. I roll the throttle and then just keep a little pressure on top the grip with my hand and don't grip it. Works much better for me. |
Author: | Tenpoint [ Mon Feb 14, 2011 7:23 pm ] |
Author: | latravcha [ Mon Feb 14, 2011 7:25 pm ] |
On long runs I grab the rubber way back where it meets the metal I Find it easier to hold |
Author: | POKER1 [ Mon Feb 14, 2011 7:46 pm ] |
Author: | Crews [ Mon Feb 14, 2011 8:48 pm ] |
balance your prop |
Author: | stonewall65 [ Mon Feb 14, 2011 9:08 pm ] |
Ok, two folks said balance the prop....how? I don't mind sounding ignorant, when that is exactly what I am. I'll also try not hangin on so tight (probably a good idea in case I hit anything) Thanks for all the guys on here who don't mind sharing some knowledge and experience, so we all benefit! |
Author: | cb5331 [ Mon Feb 14, 2011 9:30 pm ] |
Take it to a prop shop and have it balanced. Call around in your area, there is probably more than one. Tell them what you have and get a quote. Take it to who you are most comfortable with. |
Author: | deadbird8 [ Tue Feb 15, 2011 6:54 am ] |
If you have CT- try a bike glove (fingerless w/ padded palm) on your throttle hand. Helps dampen the vibration. |
Author: | bfenn [ Fri Feb 18, 2011 1:36 pm ] |
I had bad vibration with a new pd prop, had it balanced, still no help talked to Peck at pd sent it back to him. He said it had a warped blade and must have come out of the mold to hot, so he sent me a new one. |
Author: | stonewall65 [ Fri Feb 18, 2011 9:57 pm ] |
Well, I am going to remove the prop, and run it on the trailer at idle, to see if the problem is there. If it still vibrates without the prop, I'll know the problem is somewhere else. |
