Re: 36HP Pro-Drive Governor
I got in trouble the last time I posted something here from over there.
Not sure you would be able to view it unless you are a member anyway. Getting "approved" takes a few days if you are not already a member.
If nobody's posted how to fix it yet by the time I get off work tomorrow, I'll try to search over there for it and post how to do it.
Don't know if this will help or not, but here is how to set it on the kohler: Turn the linkage towards the carb as far as it will go. Turn the shaft itself counterclockwise until it stops. Tighten the bolt that clamps down the linkage onto the shaft.
