It is currently Sat Jul 05, 2025 8:23 pm
[ 4 posts ] |
fowl habbit
Joined: Sat Jan 16, 2010 1:52 pm Posts: 1130 Location: THE ONE AND ONLY BUFFALO COUNTY
 Crankcase Bolts
Im in the proccess of ordering some new crankcase bolts. my question is on the parts diagram they show 2 different bolts. I cant remeber how many of each one I need their is the 50mm and 55mm
Thu Mar 17, 2011 7:55 am |
deadbird8
 Re: Crankcase Bolts
Believe there are only 2 of the longer bolts. If I remember right they were at #6 and #3 below (but I have slept since I did the last one). But I have been told the 55mm bolts are _ONLY_ to be used when you have a stock muffler and it has the new braces that go down to the crancase cover.........If you remove the stock muffler/lower brace you MUST either get a shorter bolt or put a couple washers in its place because it will actually punch a hole thru the block into the crankcase when it bottoms out, and eventually leak oil thru the threads of the bolt.
Fri Mar 18, 2011 6:14 am |
fowl habbit
 Re: Crankcase Bolts
Hey Thanks I ended up oredering all shorth ones since I have the Croosover Muffler with the new Braces. Thanks again probally goin to order the cam also since I already have the motor apart
Fri Mar 18, 2011 10:35 am |
deltaduckmaster
 Re: Crankcase Bolts
If you had problems with leaks I would just order studs they are Lil costly but worth the $
_________________ 17x48 extreme stage 2 GTR 20X60 DUAL RIG BOWFISHING ADDITION http://www.scalesandtailsbowfishing.com
Fri Mar 18, 2011 11:11 am |
[ 4 posts ] |
Users browsing this forum: No registered users and 171 guests |
