It is currently Thu Jul 03, 2025 8:13 am
Reply to topic  [ 41 posts ]  Go to page 1, 2  Next
 Which Mods affect reliability
Post Which Mods affect reliability
I am looking at the MB Black death 5500 for my 1854 Excel. I don't run all out for speed by any means, just want an efficient motor with power (occasionally) when needed.
Q: Which modifications adversely affect reliability the most and why?
I am NOT a tinkerer, however my dealer says the BD series maintains stock cam and pistons, so is reliable.
Are BPS SS valves, rockers and twin Mikunis going to make this thing really tempermental?
What do ya'll think?
" I am the way, the truth and the life, no one comes to the Father but through Me"...Jesus Christ
Mon Oct 25, 2010 8:12 am
Post Re: Which Mods affect reliability
Only thing I can say wit certainty is dat every motor I know of dat went "BOOM" had a Mikuni carb on it. And I do not know of any modded motors wit a stock carb to go "BOOM". I am not sayin da Mikuni is da reason, dis is just an observation of mine. Da main thing is don't raise your compression or your RPM's too high. Wit da new CDI engines RPM's being to high may be a thing of da past, but you never know, anything manmade can fail.
Mon Oct 25, 2010 8:23 am
Single carb (BD4500) will be easier to adjust/maintain- IMO (I run the equivalent of it with a little extra)
The head work and exhaust on that motor are a proven recipe that are not affecting reliability.
Mon Oct 25, 2010 4:20 pm
I have a BD 5500 and would get the BD 4500 if I had to do it again. Mine was running way too rich on one cylinder and lean on the other. I have since adjusted everything and it's running great but I can't imagine the extra carb making all that much difference. It does suck more gas though and I only have 11 hours on it so I can comment on longevity but I'll let you know at the end of this duck season.
"We Are Products Of Our Decisions"
Mon Oct 25, 2010 5:47 pm
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Mon Oct 25, 2010 8:31 pm
Team Camo, I'm believing it! makes a lot of sense. I am not a tinkerer...sounds like the 4500 is a better bet for me.
So, the SS valves and stuf is not so much an issue?
I'm also wondering what real HP ya get from the BD 4500 & 5500 as the website says these numbers are NOT HP indicators? Not that I care a lot as I'm good with my present PD-36, just want newer and perhaps a bit more power if I run a full load.
Mon Oct 25, 2010 8:58 pm
Mon Oct 25, 2010 9:41 pm
I was just fixing to say that QC, i think you like the motor alot more with a stage 1. You'll get the power you are looking for!
Mon Oct 25, 2010 10:09 pm
BUCK OFAMA
Tue Oct 26, 2010 11:13 am
BJ, you know alot more than me bout these engines, and I believe if can happen. I just didn't know of any.
Tue Oct 26, 2010 11:27 am
I kinda been thinking about a mikuni..... Just been unsure about that as of yet.
Tue Oct 26, 2010 12:17 pm
all of 'em are over-rated!
Tue Oct 26, 2010 12:53 pm
Tue Oct 26, 2010 3:01 pm
:roll:
Tue Oct 26, 2010 3:10 pm
Gator Trax 1854 ran over by drunk driver!! ( boat less)
Tue Oct 26, 2010 7:22 pm
Tue Oct 26, 2010 11:38 pm
Mods are kinda like liquer,gambling, drugs, and whores. Der all fun in moderation, you just got to know when to stop.
Wed Oct 27, 2010 4:31 am
Wed Oct 27, 2010 8:06 am
Wed Oct 27, 2010 11:24 am
I would say a mikuni setup would go boom faster because of there being no rev limiter( thats if you didnt install one) But it swings both ways I guess.
BUCK OFAMA
Wed Oct 27, 2010 6:55 pm
granted u lose the govener but the mikuini is tunable right with the rev limiter installed ur ok
16x56 epidemic slick bottom with mini 4000
Wed Oct 27, 2010 8:01 pm
Re: adding Stage one to existing PD...I think with the amount of hours I suspect is on this motor (200 +/-) I would prefer a new motor anyways. Also, I have a MB dealer/friend fairly close.
Thu Oct 28, 2010 9:43 pm
To be successful, you must decide exactly what you want to accomplish, then resolve to pay the price to get it.
Thu Oct 28, 2010 9:46 pm
Sat Oct 30, 2010 10:34 am
BUCK OFAMA
Sat Oct 30, 2010 2:00 pm
Sat Oct 30, 2010 3:19 pm
Sat Oct 30, 2010 5:23 pm
all of them do, some one way some the other. One piece ss valves add life, decking heads and larger carbs shorten life. Any thing that allows you to carry a given load faster or a heavier load the same speed is either doing it by compression (additional torque) or rpm (gearchange or additional hp through more flow and cam timing)
One adds wear one adds strain neither is good for the life of a engine.
JD
Sat Oct 30, 2010 6:21 pm
BUCK OFAMA
Thu Nov 04, 2010 8:38 pm
Thu Nov 04, 2010 8:41 pm
Thu Nov 04, 2010 9:47 pm
yes you would and don't doubt me on this craig because i did stay at a holiday inn suite and im feeling pretty good.
Starting to wonder why my mother always called me special.
1750 GatorTrax HDeck 45 performance v-twin marshmellow double barrel exhaust
premium oak reverse w/minnkota cruise control
Tue Apr 05, 2011 10:29 pm
Besides having no rev limiter (by the operators choice) with a MIkuni carb the only other reason one may see more motors that have went BOOM is because the motor is making more power. More power usually equates to running WFO all the time are carrying as much sh*t as possible at WFO therefore putting more load and strain on the engine. There is a difference in a motor turning 4000 rpms light loaded and 4000 rpms with it's tounge hanging out.
Wed Apr 06, 2011 5:33 am
At 120 hours I lost my Cam shaft. If bent a push rod. 36 HP- PD
Purcahsed 10/08 broke Jan of 2011 Just out of warranty. :evil:
So I am getting a new one installed.
I hope the new one last longer than the stock.
I am getting a high TQ version installed by a guy who works on racing go-carts and mowers.
He told B/S was having cam shaft issues.
No good deed goes unpunished
Wed Apr 06, 2011 6:52 am
i currently have a gtr with stage one :mikuni,heads,cam,and exhaust. next time it will have stock carb. no adjustments and no headache. burnt motor up once bc of it
Wed Apr 06, 2011 7:00 am
I mean you guys must be running the piss out of ya'lls motors to be having all these problems! This is the first thread i have seen where people are complaining about the Mukuni's burning their motors up.
Wed Apr 06, 2011 7:58 am
How many adjustments are u having to make on your mikuni that make it that much of a hassle?
18'x54"CC Hanko/ 36PD
Wed Apr 06, 2011 9:37 am
Wed Apr 06, 2011 9:45 am
Wed Apr 06, 2011 9:50 am
I had 2 stage 3's go boom both times was the connector rod's which was after market . My current motor has stock rods in it. As for how one runs their motors people who ride around all the time with 2 people and a icechest they will last forever my rig is always loaded down to the gill they don't last long under pressure
17x48 extreme stage 2 GTR
Wed Apr 06, 2011 11:06 am
Users browsing this forum: No registered users and 87 guests
