It is currently Thu Jul 03, 2025 5:05 am
Reply to topic  [ 4 posts ]
 35 Briggs compression
Post 35 Briggs compression
I have a 2005 GDSD with a 35 Briggs. Should I be able to turn the prop by hand or should the motors compression make it to hard?
Sat Mar 26, 2011 10:41 am
Post Re: 35 Briggs compression
The compression from the motor will give you some resistance, but you should be able to turn the prop.
Sat Mar 26, 2011 10:44 am
Ok thanks. Seems like I remember not bein able to turn it when I first got the motor and we ran it pretty hard last nite so I was worried
Sat Mar 26, 2011 11:11 am
make sure you do not have the key in the on position when turning the prop... the motor can crank...... just a lil fyi....
Sat Mar 26, 2011 12:44 pm
Users browsing this forum: No registered users and 135 guests
