Tachometer ?
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=17429
Author:  Fowltalker [ Sun Apr 03, 2011 7:36 pm ]
Post subject:  Tachometer ?
Has anybody ever hooked up a analog tachometer on a mud motor ?
Author:  Fowltalker [ Mon Apr 04, 2011 8:31 pm ]
Post subject:  Re: Tachometer ?
Really ! Nobody has done this ?
Author:  Fowltalker [ Thu Apr 07, 2011 8:14 pm ]
Alright then!!!
Author:  pokey79 [ Tue Apr 12, 2011 8:51 pm ]
i think all jr dragster engines are single cylinder!!!
Author:  chad454 [ Wed Apr 13, 2011 11:30 am ]
cartpartsplus.com make a dial tach that i put on my boat and it comes with a back light for them early morning runs do the duckblind. it works perfect. i mounted it inside my boat instead of on the motor to be able to see without turning around and to keep the vibrations off it so it will last longer. hope this helps
Author:  pokey79 [ Wed Apr 13, 2011 8:42 pm ]
Good Deal i hope it works out for ya!!!!!!!!!!!!!!!!!!!!!!!!
Author:  MaXXis85 [ Thu Apr 14, 2011 7:03 am ]
http://autometer.com/cat_gaugedetail.as ... 836&sid=15
http://www.autometer.com/download_instruction/435C.pdf
Here is the Mudbuddy wiring diagram. Basically any anoalog tach wires into the Negative side of the coil. So get signal from that. If you look at the Diagram you can get sigal at the coils, or at the kill switch whatever has easiest access for you.
http://www.mudbuddy.com/_includes/MB%20 ... 2045HD.pdf
Author:  MaXXis85 [ Thu Apr 14, 2011 7:36 am ]
