how much to deck heads
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=17550
Author:  bowfishingnut [ Thu Apr 07, 2011 10:20 am ]
Post subject:  how much to deck heads
I know this has been tossed around some on here after searching the forums for info. I never ran across some solid numbers. Does anyone know what compression = how much decking.
Say you wanted to run no more than 9.5 :1...how much would you deck the heads?
I may be wrong but on pump gas you should not go over 10:1 correct?
Author:  deadbird8 [ Thu Apr 07, 2011 8:10 pm ]
Post subject:  Re: how much to deck heads
Stay conservative
Author:  bowfishingnut [ Thu Apr 07, 2011 9:04 pm ]
I understand your point and agree. Just trying to figure out how much compression some of these .060 decked heads are running vs lets say .025
Author:  BradS [ Thu Apr 07, 2011 9:12 pm ]
Id say nothing more than .030
Author:  bayouboy [ Thu Apr 07, 2011 9:51 pm ]
What if you took a 10:1 motor and made it pull in 1.5 cups? would 1.5 x 200= BOOM?
Author:  bfenn [ Thu Apr 07, 2011 10:02 pm ]
just put flat top pistons in, and don't deck
Author:  bayouboy [ Thu Apr 07, 2011 10:15 pm ]
Author:  bayouboy [ Thu Apr 07, 2011 10:19 pm ]
Author:  deadbird8 [ Fri Apr 08, 2011 5:46 am ]
Author:  MaXXis85 [ Fri Apr 08, 2011 6:19 am ]
Deck your heads in the .020-.030 range.
Author:  craig [ Fri Apr 08, 2011 7:28 am ]
I love seeing all you Briggs fe's giving advice on head decking....
Author:  BradS [ Fri Apr 08, 2011 7:55 am ]
Well do tell then Mr Briggs
Author:  MaXXis85 [ Fri Apr 08, 2011 7:57 am ]
Author:  craig [ Fri Apr 08, 2011 4:16 pm ]
Author:  BradS [ Fri Apr 08, 2011 5:36 pm ]
OOPS === guess thats what I get for not reading it all the way -- LOL
Author:  drake1 [ Fri Apr 08, 2011 7:18 pm ]
Stock Briggs is 8.5 to 1.
Author:  garrettpearce [ Fri Apr 08, 2011 7:24 pm ]
im no mechanic but it sounds like if you leave your heads stock you would have more power, just put a cam exhaust and carb and be done with it...correct?
Author:  drake1 [ Fri Apr 08, 2011 7:50 pm ]
Both will make more power. Do both together and make a lot more power.
Author:  bowfishingnut [ Fri Apr 08, 2011 8:33 pm ]
The point of my post was simply to see if anyone knew what kind of compression was being run from say .060 decked heads and say .025 decked heads since I have read those numbers allot on here. Stock compression according to vangaurds web site says 8.2 to 1. ( http://www.vanguardengines.com/vanguard ... al%20Shaft
Author:  craig [ Sat Apr 09, 2011 7:25 am ]
Author:  quackconsumer [ Sat Apr 09, 2011 8:21 am ]
So what would be best to deck my heads wit, a hammer and chissel or a hacksaw ???
Author:  craig [ Sat Apr 09, 2011 8:22 am ]
Author:  quackconsumer [ Sat Apr 09, 2011 8:27 am ]
Author:  Woodiebuster [ Sat Apr 09, 2011 8:29 am ]
Make sure you have plenty of silicone , it holds up better than stock gaskets and hugs the contours of the grind if not done evenly.
Author:  BradS [ Sat Apr 09, 2011 10:26 am ]
Author:  quackconsumer [ Sat Apr 09, 2011 10:31 am ]
Figures.....
The first thing that comes to Brad's mind is allways food.
Author:  bayouboy [ Sat Apr 09, 2011 10:40 am ]
This thread is about ENGINE compression not ASS compression Brads!
Author:  BradS [ Sat Apr 09, 2011 10:41 am ]
Compression is compression -- lOL
Author:  bayouboy [ Sat Apr 09, 2011 10:44 am ]
