instructions on changing heads http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=17554 |
Author: | smboudreaux [ Thu Apr 07, 2011 12:30 pm ] |
Post subject: | instructions on changing heads |
anyone have a link to step by step instructions on changing heads? its on a 04 mudbuddy 29. tired search and came up with zero |
Author: | OwenDickeson [ Thu Apr 07, 2011 12:36 pm ] |
Post subject: | Re: instructions on changing heads |
unbolt heads remove heads and clean all old gasket material put on new gasket and bolt up new heads put in push rods and set valve lash I'm sure someone could go into a lot more detail but there is really no need. Changing your heads is very simple. |
Author: | Bubby83 [ Thu Apr 07, 2011 3:36 pm ] |
"set valve lash" Can someone ellaborate on how this is done? |
Author: | MaXXis85 [ Thu Apr 07, 2011 3:37 pm ] |
Author: | caddobrook [ Thu Apr 07, 2011 4:17 pm ] |
make sure you torque everything to spec.... |
Author: | Bubby83 [ Thu Apr 07, 2011 5:14 pm ] |
Where might I find torque specs? |
Author: | OwenDickeson [ Thu Apr 07, 2011 5:22 pm ] |
prolly a briggs manual |
Author: | caddobrook [ Thu Apr 07, 2011 5:29 pm ] |
Author: | OwenDickeson [ Thu Apr 07, 2011 6:03 pm ] |
You might be able to download a PDF of it somewheres online. |
Author: | craig [ Thu Apr 07, 2011 6:22 pm ] |
Author: | deadbird8 [ Thu Apr 07, 2011 8:08 pm ] |
Author: | dguidry [ Thu Apr 07, 2011 9:03 pm ] |
Author: | OwenDickeson [ Thu Apr 07, 2011 9:04 pm ] |
Author: | deadbird8 [ Fri Apr 08, 2011 5:43 am ] |
Author: | Bubby83 [ Fri Apr 08, 2011 5:52 am ] |
From what I have about 1/4" past TDC, it sounds like if you set lashing at TDC on a Van. you will actually be setting lash while the compression release is engaged. |
Author: | MaXXis85 [ Fri Apr 08, 2011 6:11 am ] |
Author: | OwenDickeson [ Fri Apr 08, 2011 7:02 am ] |
Author: | MaXXis85 [ Fri Apr 08, 2011 7:12 am ] |
Author: | craig [ Fri Apr 08, 2011 7:17 am ] |
Author: | MaXXis85 [ Fri Apr 08, 2011 7:21 am ] |
Author: | dguidry [ Fri Apr 08, 2011 7:43 am ] |
Just received my Briggs repair manual. Wish i'd have had it when I installed my cam and heads. It's excellent, very detailed step by step instructions on everything one can think of doing to the engine. $20 plus shipping. Get you one. |
Author: | deadbird8 [ Fri Apr 08, 2011 5:58 pm ] |
Author: | garrettpearce [ Fri Apr 08, 2011 7:15 pm ] |
Author: | XGEN-DUCKMAN [ Fri Apr 08, 2011 7:20 pm ] |
Lash should set when the valve is closed, past tdc or the YouTube way should work..... |
Author: | XGEN-DUCKMAN [ Fri Apr 08, 2011 9:33 pm ] |
Just finished installing my new heads and tried it both ways, didn't notice a difference...... both held at .005.... |
