It is currently Thu Jul 03, 2025 8:42 am
Reply to topic  [ 8 posts ]
 Tachometer ?
Post Tachometer ?
Has anybody ever hooked up a analog tachometer on a mud motor ?
1648 weldbilt pushed by a Mudbuddy 35hd
" People are like slinkies pretty well useless, until you see one go down the stairs then you smile."
Sun Apr 03, 2011 7:36 pm
Post Re: Tachometer ?
Really ! Nobody has done this ?
Mon Apr 04, 2011 8:31 pm
Alright then!!!
Thu Apr 07, 2011 8:14 pm
i think all jr dragster engines are single cylinder!!!
Tue Apr 12, 2011 8:51 pm
cartpartsplus.com make a dial tach that i put on my boat and it comes with a back light for them early morning runs do the duckblind. it works perfect. i mounted it inside my boat instead of on the motor to be able to see without turning around and to keep the vibrations off it so it will last longer. hope this helps
17x52 x-treme with 35-GTR Stage 2.25
Wed Apr 13, 2011 11:30 am
Good Deal i hope it works out for ya!!!!!!!!!!!!!!!!!!!!!!!!
Wed Apr 13, 2011 8:42 pm
http://autometer.com/cat_gaugedetail.as ... 836&sid=15
http://www.autometer.com/download_instruction/435C.pdf
Here is the Mudbuddy wiring diagram. Basically any anoalog tach wires into the Negative side of the coil. So get signal from that. If you look at the Diagram you can get sigal at the coils, or at the kill switch whatever has easiest access for you.
http://www.mudbuddy.com/_includes/MB%20 ... 2045HD.pdf
Thu Apr 14, 2011 7:03 am
Thu Apr 14, 2011 7:36 am
Users browsing this forum: Google [Bot] and 108 guests
