GTR23 Mikuni Install Issue. Ex Manifold/muffler options help
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=17702
Author:  dguidry [ Tue Apr 12, 2011 6:09 pm ]
Post subject:  GTR23 Mikuni Install Issue. Ex Manifold/muffler options help
I want to install a Mikuni carb on mt GTR23. BPS says I need their single crossover manifold/exhaust so it will fit. Stock manifold/muffler does not have necessary clearances for the air filter. I want to build my own manifold and muffler combo, preferably straight back pipe for each exhaust outlet. I have questions, but here is what I think I already know about this:
1. OD for manifold pipe is 1.25".
2. Have to fit flange to pipe either welded or compression coupling of some kind or slip on(?).
3. Muffler to manifold coupling can be welded or fitted and clamped.
4. I'll need to support each exhaust with connections to crankcase bolt points.
I need the following:
1. Exhaust pipe supplier
2. Flange and mechanical coupling supplier
3. Exhaust supplier.
4. Your suggestions, and I don't need to hear "buy one you idiot" cause that would be too easy. Remember it's my journey.
Thanks.
Author:  Woodiebuster [ Tue Apr 12, 2011 7:37 pm ]
Post subject:  Re: GTR23 Mikuni Install Issue. Ex Manifold/muffler options
Search is your friend.
http://mudmotortalk.com/mmt_v2/viewtopi ... 35#p116535
Author:  dguidry [ Wed Apr 13, 2011 4:58 am ]
Bumparoosky
Author:  dguidry [ Thu Apr 14, 2011 10:33 am ]
I looking to put something together from these sources:
Author:  dguidry [ Thu Apr 14, 2011 10:40 am ]
Ya'll think two of these might work:
Author:  pooldoo73 [ Thu Apr 14, 2011 2:03 pm ]
I hope those come wif earmuffs.
Author:  jordy [ Thu Apr 14, 2011 2:50 pm ]
Author:  dguidry [ Thu Apr 14, 2011 3:17 pm ]
I need to but a damn welding machine. If I could build a flange/manifold muffler out of wood I would.
Author:  dguidry [ Thu Apr 14, 2011 3:22 pm ]
I talked to fellow out of California who will sell me some flanges with about 4" of pipe and a 2 into 1 collector. He said to use flex exhaust pipe for everything in between....works like a champ. The flanges and collector will cost a total of about $50. Anyone know the bolt center to bolt center of a Vanguard 23 exhaust flange?
Author:  MaXXis85 [ Thu Apr 14, 2011 3:24 pm ]
WHy not talk to dan at MM and get some peices and make a MM fit your 23. They sound great.
Author:  SuperDave4x4 [ Thu Apr 14, 2011 8:39 pm ]
Author:  med [ Thu Apr 14, 2011 9:29 pm ]
Author:  MaXXis85 [ Fri Apr 15, 2011 5:35 am ]
Flex hose just looks cheap as phuck. Like I said before, Id buy a MM in pieces and make it work on da 23.
Author:  med [ Sat Apr 16, 2011 8:00 pm ]
What kind of flex pipe are you going to use d?
Author:  dguidry [ Sun Apr 17, 2011 9:38 am ]
Here
Author:  Woodiebuster [ Sun Apr 17, 2011 9:40 am ]
Why would you want that? It looks like it should be comin out a dryer.
Author:  meterman3 [ Sun Apr 17, 2011 9:00 pm ]
dg call dan at mm and spend the money once and be done with it and it sounds great not to loud but great tone
Author:  med [ Sun Apr 17, 2011 11:44 pm ]
I think I'm going to use that same stuff on mine. I'm rigging an old bps on my 27. Theres nobody around that can bend that small pipe without kinking it. I'm only going to be using 3-4"on each side. I'm enrolling in a welding course at the college this fall then I'm going to build one.
Sent from my SCH-I400
Author:  med [ Sun Apr 17, 2011 11:46 pm ]
Post subject:  Re: Re: GTR23 Mikuni Install Issue. Ex Manifold/muffler opti
Author:  dguidry [ Mon Apr 18, 2011 12:19 am ]
Author:  med [ Mon Apr 18, 2011 1:13 am ]
If you aren't dead set on buying a muffler u should check out the one in the kohler forum on mb. A guy over there built one that looks real good. Didnt k know if you had access to a welder. I've talked with him thru pms and he has been very helpful. Thats the one I think I'm going to try when I get started in my welding course...among many other projects. My wife is gona be pissed when I take over the garage :mrgreen:
Author:  dguidry [ Mon Apr 18, 2011 8:09 am ]
Author:  med [ Mon Apr 18, 2011 9:24 am ]
http://www.mudbuddy.com/forum/double-ba ... 12050.html
