gtr 35 speed problem http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=17797 |
Author: | Txphi796 [ Sun Apr 17, 2011 2:53 pm ] |
Post subject: | gtr 35 speed problem |
I have a question about a GTR 35 on a 1752 alweld boat. I just got it repaired because the diodes went out in it so it runs great but i used to go alot faster over open water. I was fishing yesterday with three people in the boat and a full load of gear doing 26 mph across the shallow water but went i went deep i could not get above 18 mph. Does anyone know why it would not go faster than that over open water or is there a way to fix that. it used to do alot faster. |
Author: | Woodiebuster [ Sun Apr 17, 2011 2:56 pm ] |
Post subject: | Re: gtr 35 speed problem |
Is your hull in great condition on the bottom? |
Author: | Txphi796 [ Sun Apr 17, 2011 10:59 pm ] |
the hull is not in that bad of shape. Its has a few scars but no bends in it . |
Author: | take'emgator [ Mon Apr 18, 2011 7:43 am ] |
I am gonna lean towards your prop |
Author: | LA Mudder [ Mon Apr 18, 2011 10:32 pm ] |
sure your throttle cable aint slipped back some? |
Author: | Txphi796 [ Tue Apr 19, 2011 10:55 pm ] |
The throttle cable seems to be ok but how do i check that? My prop is a little chewed up from sand but it doesnt look that bad? with just me in the boat it will do near 30 mph. I guess the problem is in open water with a load it wont get up on plane. |
Author: | Txphi796 [ Tue Apr 19, 2011 10:57 pm ] |
What if i put some sort of cavitation plate on it would that do the trick? |
Author: | WestEndAngler [ Wed Apr 20, 2011 6:29 am ] |
Author: | Garland [ Wed Apr 20, 2011 7:09 am ] |
I have the same problems and I am running a 1752 gt extreme and I had three people in the boat with a fishing load and it would only run 18mph. The motor would only turn around 3400 rpm's and usually it runs around 3800 rpm's. |
Author: | WestEndAngler [ Wed Apr 20, 2011 7:19 am ] |
Author: | Txphi796 [ Fri Apr 22, 2011 6:13 pm ] |
How do i adjust the govenor? Should i move the spring to a drifferent slot? Will that hurt the motor? |
Author: | garrettpearce [ Fri Apr 22, 2011 7:15 pm ] |
Pull the throttle cable at the screw until you have a 1/8 of play at the handle while running |
