| intermitent ignition on 23 hp vanguard http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=1783 |
| Author: | 1duckcrazy [ Mon Apr 27, 2009 5:24 pm ] |
| Post subject: | intermitent ignition on 23 hp vanguard |
Anyone have any insight on what might be the problem? Battery is full charged and connections have all been cleaned and checked. I have 12+ volts up to the point it connnects to the black block with 2 studs on it. Sometimes it will start and other times nothing but need to figure it out so I can trust it on the river with fast current. I am thinking key switch or the black block but not sure, starter seems fine. Thanks 1 duckcrazy |
| Author: | 50fps [ Mon Apr 27, 2009 6:21 pm ] |
| Post subject: | Re: intermitent ignition on 23 hp vanguard |
If your talking about the starting circuit, you probably need to pick up a new solenoid. Next time it gives you problems hit the black thingy with the handle of a screw driver and see if it cranks. |
| Author: | Silkpower [ Tue Apr 28, 2009 10:46 am ] |
