Oil Leak
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=18130
Author:  jd44 [ Fri Apr 29, 2011 6:24 am ]
Post subject:  Oil Leak
What's your opinion on this one? I have a oil leak coming from my block, but it's a very small one. Not sure if I have a pin hole in the gasket or something like that but I noticed it about 2trips ago and I keep monitoring the oil level to make sure I'm ok. I haven't even noticed a change on the dipstick yet. Is it something I should be worried about even though I'm not leaking alot of oil?
Author:  WestEndAngler [ Fri Apr 29, 2011 6:41 am ]
Post subject:  Re: Oil Leak
That's a case gasket leak & they almost ALL for the most part do this... I think its like arond ~ $100 to replace if that sometimes dealers will warranty just have to call & ask.
Author:  drake1 [ Fri Apr 29, 2011 7:09 am ]
Only worry if you have to keep tightening the bolts in the cover. Have seen a few motors weld the cams to the cover because of loss of clearance between the two.
Author:  wabbit-hunter [ Sun May 01, 2011 4:00 pm ]
Just brought my boat to calens engine service in Franklin for the same problem.He explained to me why they leak right there, they all do sooner or later. My valves was leaking also,80% on one side and 40% on the other. He been having it for two weeks, i cant wait to get it back and go see if it makes a difference.
Author:  BAG Hunter [ Sun May 01, 2011 4:05 pm ]
so what did he say about why they all leak there?
Author:  JIMMY W [ Sun May 01, 2011 4:05 pm ]
Get one of the foam wrapped metal gaskets from EVT and be done with it ;)
Author:  wabbit-hunter [ Sun May 01, 2011 4:21 pm ]
They have two holes that feed the oil filter that is pressurized,and the bolt holes are to far away.
Author:  Sko [ Sun May 01, 2011 4:27 pm ]
Mine just started that today .
Author:  wabbit-hunter [ Sun May 01, 2011 4:45 pm ]
How much did your stage one cost you, my warranty is almost done?
Author:  Sko [ Sun May 01, 2011 4:46 pm ]
About 1800
Author:  Sko [ Sun May 01, 2011 4:47 pm ]
Let me know what you so with that oil leak.
Author:  deadbird8 [ Sun May 01, 2011 7:04 pm ]
If its still under warranty have briggs pay for the repair.
Author:  Chico80x [ Sun May 01, 2011 7:16 pm ]
Mine started doing it at 30 hours.
Author:  wabbit-hunter [ Sun May 01, 2011 7:19 pm ]
Briggs is payn for my repairs to the gasket and the valves,thank god for warranty i just have 103hrs on the motor.
Author:  wabbit-hunter [ Wed May 04, 2011 8:31 pm ]
Finally got my boat back from the machnics shop,gained 300 rpm's and 4mph. Im so ready to go bowfishing now.
Author:  OwenDickeson [ Wed May 04, 2011 8:39 pm ]
cool, what did he do to fix your valves? Lap them in?
Author:  marsh chicken [ Thu May 05, 2011 7:52 am ]
I got the same issue with my GTR right now. Im worried about having a briggs lawnmower place do the repairs just bc I don't know how hard it will be to get the clutch off, since they arent familiar with that part. anyone know if this should be an issue? also, put IM heads, with rockers, and pushrods, wondering if my warranty might be void anyway bc of this.
Author:  Mudhead [ Thu May 05, 2011 12:06 pm ]
Author:  wabbit-hunter [ Thu May 05, 2011 8:29 pm ]
All i know is one was leaking 80% and the other 40%. It had 40lb difference in compression,its fixed now.
