It is currently Thu Jul 03, 2025 4:53 pm
[ 7 posts ] |
Flat stop on step-off, 32hp PD
Mudhead
I've got decked heads, BPS cam, and gutted exhaust. My mid-range punch is great, and top end is strong. The only issue I've noticed is if I hammer the throttle from idle, the motor wants to hesitate. I can't jump on step fast without feathering the throttle a little before going to full. This happens from about 900 rpm at idle, with prop engaged, until I hit about 2,000RPM or so.
I've heard this was an inherent problem with the 32's. I'm wondering if switching to the 36 carb might help, or if it's just something I'm stuck with. Not that big of a deal, just thought there might be a fix for it.
_________________ Geaux 1848, 32PD w/stage III case gasket and decked valve covers
Thu May 05, 2011 12:23 pm |
shooter
 Re: Flat stop on step-off, 32hp PD
I've got a 32 I just set up with a 36 carb, K&N Filter and Marshmellow exhaust. Still had hesitation, I posted a thread on the issue and got some helpful responses. Went with a Facet electric fuel pump, that seemed to help some. Still have the problem, but not near as bad as before.
_________________ 32 PD with EVT cam, decked heads, shaved pistons and not enough sense to leave things alone!
Thu May 05, 2011 1:20 pm |
OwenDickeson
Mikuni
Thu May 05, 2011 1:38 pm |
Gatorpoint
Joined: Tue Jan 13, 2009 8:09 pm Posts: 1175 Location: A slough behind you, TEXAS
Never ran a stock 36 carb on a 32, but most on here will agree the stock carbs have a flat spot on the bottom end. Get a mikuni and you wont look back.
_________________ 1854 Brotha Breaux Bateau pullin' a 35 GT arrrrahhh! Willett Welding custom boat trailer
Thu May 05, 2011 5:22 pm |
XGEN-DUCKMAN
Joined: Fri Jan 16, 2009 3:51 pm Posts: 195 Location: BackWaters of Wisconsin
_________________ If I can't Break it, it can't be Broke.............................
Thu May 05, 2011 8:40 pm |
Mudhead
Fri May 06, 2011 5:15 pm |
XGEN-DUCKMAN
Oh it took longer then 2 seconds......
Fri May 06, 2011 7:01 pm |
[ 7 posts ] |
Users browsing this forum: No registered users and 130 guests |
