It is currently Tue Sep 16, 2025 2:14 pm
Reply to topic  [ 12 posts ]
 35 vanguard ALTERNATOR
Post 35 vanguard ALTERNATOR
if you start a 35 vanguard then disconnect the battery and it dies does that mean the alternator is bad???? we went bowfishin the other night and had a 10 mile paddle when we decided to head back!! just want to make sure if its only the battery or the alternator.
THANKS
18X60 GDSD
35 HP GDSD
FPR (full push reverse)
Thu Apr 30, 2009 5:41 pm
Post Re: 35 vanguard ALTERNATOR
Put a meter on the battery. 12v + equal good battery. Rev up motor and it should show around 14v or so if it's charging. Someone said you had to have battery connected for motor to run at all, don't know about that one though.
18x48 Charles Leonard / 36PD
Thu Apr 30, 2009 7:25 pm
It starts charging at ~1800-2000RPM. You need some electricity for the clutch if you have one- I expect you would need some juice to engage it.
Other things would be the anti-backfire valve and oil sensor- they may need power to allow it to run, but never have tried to run it without a battery.
Thu Apr 30, 2009 7:32 pm
I don't thank this type of engine has gots a "alternator" !!! It do have a "mild" type rechargin' system that sux when it comes to lights !!!!
Put the purchace on a new battrey ever season with the old one has a back-up ever year and make shore you gots some form of pliers handy !!!
Nature of the "Beast" is what it is !!!!! :lol:
Thu Apr 30, 2009 9:04 pm
Get you one of them small onboard chargers and plug in when you get home to ensure a full charge for the next trip. Then you won't have to worry about the capacitor having to work hard on the charge while running each time.
Thu Apr 30, 2009 10:10 pm
Damn that sux! Don't no bout the alternator but you shoulda gave me a holler bro instead of paddlin!
Sold my boat so now im ridin in a cozy pick-up truck to the blind to shoot ducks and a 60' Hatteras to catch fish on
Fri May 01, 2009 11:25 am
It won't run without being connected to the battery.
Pro Drive m'fers
Fri May 01, 2009 8:42 pm
Fri May 01, 2009 9:17 pm
Mon May 04, 2009 10:00 am
Pro Drive m'fers
Mon May 04, 2009 10:03 am
Mon May 04, 2009 2:32 pm
You can take that solenoid off and plug the hole with a bolt. The MB 45's remove it.
Tue May 05, 2009 5:11 am
