35 vanguard ALTERNATOR
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=1851
Author:  allfoul'dup [ Thu Apr 30, 2009 5:41 pm ]
Post subject:  35 vanguard ALTERNATOR
if you start a 35 vanguard then disconnect the battery and it dies does that mean the alternator is bad???? we went bowfishin the other night and had a 10 mile paddle when we decided to head back!! just want to make sure if its only the battery or the alternator.
THANKS
Author:  POKER1 [ Thu Apr 30, 2009 7:25 pm ]
Post subject:  Re: 35 vanguard ALTERNATOR
Put a meter on the battery. 12v + equal good battery. Rev up motor and it should show around 14v or so if it's charging. Someone said you had to have battery connected for motor to run at all, don't know about that one though.
Author:  deadbird8 [ Thu Apr 30, 2009 7:32 pm ]
It starts charging at ~1800-2000RPM. You need some electricity for the clutch if you have one- I expect you would need some juice to engage it.
Other things would be the anti-backfire valve and oil sensor- they may need power to allow it to run, but never have tried to run it without a battery.
Author:  BROOKS [ Thu Apr 30, 2009 9:04 pm ]
I don't thank this type of engine has gots a "alternator" !!! It do have a "mild" type rechargin' system that sux when it comes to lights !!!!
Put the purchace on a new battrey ever season with the old one has a back-up ever year and make shore you gots some form of pliers handy !!!
Nature of the "Beast" is what it is !!!!! :lol:
Author:  POKER1 [ Thu Apr 30, 2009 10:10 pm ]
Get you one of them small onboard chargers and plug in when you get home to ensure a full charge for the next trip. Then you won't have to worry about the capacitor having to work hard on the charge while running each time.
Author:  marsh bandit [ Fri May 01, 2009 11:25 am ]
Damn that sux! Don't no bout the alternator but you shoulda gave me a holler bro instead of paddlin!
Author:  basinhunter [ Fri May 01, 2009 8:42 pm ]
It won't run without being connected to the battery.
Author:  BROOKS [ Fri May 01, 2009 9:17 pm ]
Author:  MaXXis85 [ Mon May 04, 2009 10:00 am ]
Author:  basinhunter [ Mon May 04, 2009 10:03 am ]
Author:  MaXXis85 [ Mon May 04, 2009 2:32 pm ]
Author:  deadbird8 [ Tue May 05, 2009 5:11 am ]
You can take that solenoid off and plug the hole with a bolt. The MB 45's remove it.
