It is currently Sat Jul 12, 2025 4:47 pm
Reply to topic  [ 10 posts ]
 Go Devil Upper Sprocket Removal ????
Post Go Devil Upper Sprocket Removal ????
I am replacing my crankcase gasket. Talked with Coco twice about the procedure and I am all the way up to the point where I need to remove the upper sprocket. I took the two set screws out, but how do I get the sprocket off??? If anyone can point me in the right direction, it would be much appreciated.
Tim
Sat May 21, 2011 1:22 pm
Post Re: Go Devil Upper Sprocket Removal ????
You can call me if you need help. 8323359709 I can walk you through it
23 hp gdlt pushin the 14ft NoWeld "aka" the black pearl
35 hp gdsd pushin a 16/60 go devil boat
Sat May 21, 2011 1:36 pm
Post Re: Re: Go Devil Upper Sprocket Removal ????
Sat May 21, 2011 2:30 pm
Borrow one of these from your parts dealer and it will pull it off with no trouble!
http://s1226.photobucket.com/albums/ee4 ... ller-1.jpg
http://s1226.photobucket.com/albums/ee4 ... ller_a.jpg
Sat May 21, 2011 7:22 pm
17*38 Klibert 23GDLT
Sat May 21, 2011 10:17 pm
Mon May 23, 2011 6:12 am
Mon May 23, 2011 6:18 am
I'm in the process of installing a cam and I'm now at this point.
I put the Allen screw in the 3rd hole and tightened it down. Now the sprocket is turning. How tight do you turn it? How can you hold the sprocket in place.
Can I tap the sprocket to push it off towards the motor.
Wed Mar 28, 2012 6:25 pm
Sprocket should be held in place with a key stock. Tighten that bitch down and tap the sprocket towards motor, not the two pieces in the middle.
Wed Mar 28, 2012 6:30 pm
Just got it. It needed some encouragement from a rubber mallet.
Wed Mar 28, 2012 6:39 pm
Users browsing this forum: No registered users and 125 guests
