31 gtr
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=1894
Author:  darrel from meraux [ Sun May 03, 2009 8:56 pm ]
Post subject:  31 gtr
got a 31hp gtr a few days ago, took it for a run and it idled at 1650-1700. I thought this was way too high and essentially a "clutch dump" every time i put it in gear, so i lowered the idle to 1200, this made it kinda hard to start and now when i put it in gear even in the just plain water with no mud it will kill unless i idle it back up. What do you guys have your gator tails idled at? i am running a big blade on a 20x44 500lb boat.
Author:  deadbird8 [ Mon May 04, 2009 4:55 am ]
Post subject:  Re: 31 gtr
I idle at 1000.
To keep it from killing when you engage the clutch, try adjusting the tab on the governed idle spring (should be similar to the 35- white spring on the linkage). Its a minor adjustment with a pair of pliers.
I had to do it when I installed a more aggressive prop. Bring a glove (so you don't burn your hand on the muffler) and do it in the water so you can test it immediately.
