It is currently Thu Jul 03, 2025 8:22 pm
Reply to topic  [ 8 posts ]
 RPMs at Idle
Post RPMs at Idle
23hp vanguard-gdsd- what are ideal RPMs at idle with prop out of the water? I am checking it all out in the garage and its running at 2000. When I am pushing a full load, what are safe RPMs to run at reliably? I would guess in the 4200-4400 range but what do yall think. I want to have this motor for a long time and I want to take good care of it.
23 gdsd/1542 alumacrap
Sat Jun 04, 2011 9:51 pm
Post Re: RPMs at Idle
For idle, I want my rpm's to be just high enough that it doesn't kill it when you put a load on it in the water.
Sat Jun 04, 2011 10:38 pm
x2, 1000-1200 usually. Set the gov so your out of water max is in the 4250 range.
Sat Jun 04, 2011 10:40 pm
Ok thanks. I'll put some slack in the throttle cable.
Sat Jun 04, 2011 10:49 pm
How do I set the governor. My out of water RPMs are going over 4500... I thought about putting slack in the throttle cable but that just doesn't seem right.
Sun Jun 05, 2011 9:46 am
Should be an adjustment screw down in the linkage somewhere. The one near the linkage on the carb is for your idle.
Sun Jun 05, 2011 10:36 am
Ah yes. I know the one you mean. Thks
Sun Jun 05, 2011 11:03 am
Geaux 1848, 32PD w/stage III case gasket and decked valve covers
Mon Jun 06, 2011 12:13 pm
Users browsing this forum: No registered users and 124 guests
